Has anyone heard of a terco milling machine?
No, but I have heard of Hurco, located in Indianapolis, IN.
Regards,
Chuck
There is a company called Terrco that makes carving machine (manual duplication) but I don't know if they have moved into cnc.
Mike
No greater love can a man have than this, that he give his life for a friend.
I own a Terco CNC-45 Mill. What kind of questions do you have?
Terco is a Swedish company that manufactures things for school and education. They have (or had) some CNC machines for education.
Check this link for a picture of two of them http://www.desktopcnc.com/out_of_prod/old_terco.htm
I own one of the top pictures, a 4441 milltrainer. The control accepts only 100 steps of G-code and has no computer connection. It was out of manufacture even 10 years ago, when I got it. Mine was manufactured earliest 1983.
While the control is Swedish built, I don't think the mill part is, and it probably goes by another name from an US (or possibly UK) manufacturer.
I have scrapped my control due to its limitations, and that it is big, heavy, noisy and gives a lot of heat and that mine lost its memory all the time. So now I am looking into replacing it with something modern.
Check out Mach3 or the new Quantum software from www.Artsoft.ca
artsoft.ca maybe not what you want.
Try www.machsupport.com
www.integratedmechanical.ca
Thanks for all your replies. I was looking at a mill trainer just like that 4441 a guy had for sale. I never did get the terco but was curious about the specs like spindle speed and feed screw type. I have seen two of these for sale over the years. Might never see one again. That link karolinali gave is more than info than I was able to scrape up in years. Isn't 1983 for cnc tools like 1883 for manual machine tools?
One of those was just going on ebay for $675, but with the number 4460. The photos and data are still available. It looks almost exactly like mine, so there are at least no external differences. I take data from there:
Table Speed: 0 - 20" minute
Programming Accuracy: .001"
Spindle Motor: Thyristor controlled DC motor
Table: 13.78" X 5.9"
Longitudinal Travel: 7.48"
Traverse Travel: 3.15"
Vertical Travel: 1.57"
Spindle Motor: 180W
Spindle Taper: Morse 1
Spindle Speeds: 500 - 2500 RPM
Number of Speeds: 9
Weight (Mill Only): 230 lbs.
The Terco 44XX appears very solid. It is all steel and the table is thick. I guess that can be seen from the weight. The spindle is 500-2500 rpm in step of 250. The spindle is only 180W, but looks very solid. The screw type I cannot say, since I don't know about different screw types. It looks as solid as everything else.
It just needs a completely new control. Since the mill has three steppers, such controls are easily available. The only problem then is spindle control. The spindle motor is a direct-drive permanent magnet DC-motor of unknown voltage requirement, but it looks like it was going directly on rectified mains voltage.
I got mine without a tool holder, which initially gave my problems. It is Morse 1, and a special screw fitting keeping it together. The picture for the machine on ebay looks like it has a normal drill holder, which does not work for milling. (I have tried it, and it falls out all the time).
I got mine from Terco, but it was 10 years ago, and it might have been the last spare they had.
This milling machine used to have a kit so it could double as a CNC lathe.
