586,688 active members*
2,799 visitors online*
Results 1 to 13 of 13
    Feb 2016
    9
    Gcode or problem with my CNC 3040T?
    I recently setup my CNC 3040T and after some help from a user here got everything working...or so it seemed.
    I found someone on upwork.com to make a design I created into Gcode. As soon as I loaded the Gcode into Mach3 and started the cycle my stepping motors make a loud sound. It seems they are trying to go past the bounds that the machine is capable of working on. Is this an easy fix? The design looks great from a Gcode standpoint; however, not sure if coordinates should be adjusted.
    *This is my first time using the machine*
    Any help would be greatly appreciated!
    Mar 2012
    192
    Re: Gcode or problem with my CNC 3040T?
    If you are using the stock screens, then the toolpath tab should tell you the outside work area limits.
    I think Mach will warn you if the work area is outside the table size, if you have soft limits set up for your table. You can also see the table outline if you select that display and then regenerate tool path.
    Also check if the units are in metric...
    Maybe post the first several lines of your g-code?
    Feb 2016
    9
    Quote Originally Posted by 1875 View Post
    Thanks for the insight. It looks like only part of my design falls into a rectangular solid that represents my work space. Weird because I specifically asked the designer to make it an A4 sized area.
    Units in Mach3 are in metric.
    Here is some of the Gcode I have:
    G90 G17
    G80 G49 G40
    G54
    G90
    M01
    N1 M6 T1
    ( TOOL -1- DRILL DIA 0.15 MM )
    G90 G00 G40 G54
    G43 H1 G0 X283.135 Y183.486 Z25. S8000 M3
    M8
    G10G91 L2 P1 X-270.371 Y-136.139 Z20.
    G90
    (D-DRILL - DRILL)
    G0 X283.135 Y183.486 Z5.
    Z2.
    G1 Z-0.5 F250
    G0 Z5.
    X283.493 Y183.436
    Z2.
    G1 Z-0.5
    G0 Z5.
    X283.877 Y183.298
    Z2.
    G1 Z-0.5
    G0 Z5.
    X284.305 Y183.185
    Z2.
    G1 Z-0.5
    G0 Z5.
    X284.708 Y183.059
    Z2.
    G1 Z-0.5
    G0 Z5.
    X285.079 Y182.971
    Z2.
    G1 Z-0.5
    G0 Z5.
    X285.475 Y182.845
    Z2.
    G1 Z-0.5
    G0 Z5.
    X285.815 Y182.706
    Z2.
    G1 Z-0.5
    G0 Z5.
    X286.236 Y182.593
    Z2.
    G1 Z-0.5
    G0 Z5.
    X286.632 Y182.48
    Z2.
    G1 Z-0.5
    Feb 2016
    381
    The code displayed stays well within the A4 boudaries so long as you have the orientation of the axis correct.
    Feb 2016
    9
    Quote Originally Posted by Louis_Cannell View Post
    How do I determine if my axis is correct? I'm assuming it's not.
    Feb 2016
    381
    Simply jog the X axis and make sure you are moving the axis you want to, if it is as you expect then the workpiece is loaded in wrong direction i.e. landscape portrait on a print.
    Otherwise your setting in the software are incorrect, although if you were configured correctly a4 would be ok both directions.
    Feb 2016
    9
    I see, when I jogged the left arrow key it would move the head right instead of left causing it to hit the outermost bounds of the workspace causing the noise. Not sure if this is the issue because i could easily flip the machine and be fine.
    The workpiece loaded in the wrong direction as in the Gcode?
    I appreciate all the info your shooting my way.
    Feb 2016
    381
    you need to swap 2 of the wires from 1 phase on the stepper motor that should reverse it
    or
    Under Config - Motor Home/Soft Limits, Check the Reversed column for the Axis you need to revers.
    Feb 2016
    9
    "Under Config - Motor Home/Soft Limits, Check the Reversed column for the Axis you need to revers." This worked perfectly, thank you!!
    It seems we're working in landscape instead of portrait for this design, how would I go about changing this?
    15362
    PhilipY
    Did you just want to drill some holes,then that is not how you do a program to drill holes, what really were you trying to program
    Mactec54
    Feb 2016
    9
    PhilipY
    I am trying to make micro perforations on paper. All I need done is a program to drill these holes, this program won't do that?
    15362
    Quote Originally Posted by PhilipY View Post
    Whats the grid pattern and your start point, is you machine set up in inch or metric
    Mactec54
    Feb 2016
    9
    Metric, the grid pattern is a simple rectangle for testing purposes. The start point of the Gcode or the actual machines coordinates?
  1. CnC routher machine 3040T-DJ- Problem with Controlboard
    By Matteek89 in forum News Announcements
    Last Post: 06-07-2015, 09:40 PM
  2. gcode problem
    By IonutPatrut in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-18-2012, 09:48 AM
  3. Cam to gcode problem
    By Sonicmook56 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-24-2007, 02:01 PM
  4. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  5. dxf to gcode problem...
    By freezer in forum Uncategorised CAM Discussion
    Last Post: 02-19-2004, 07:02 AM
