586,077 active members*
3,767 visitors online*
Thread: X axis brake
    Aug 2013
    18
    X axis brake
    Two of or Our cnc lathes, a 1998 okuma crown/osp700l, and 1994 cadet/osp5020 both have problems with the x axis dropping at power off or estop, drifting down to the hard stop or against a wooden block if operator puts it there.
    The last time a similar problem occurred, okuma service sold me a new motor.
    Is there a serviceable electric brake on the motor?
    Sent from my SM-G900R4 using Tapatalk
    Aug 2013
    18
    Re: X axis brake
    Update if anyone is interested. . The 1994 machine has a brake that is external from the motor. Found a coupler had come loose and moved. Repositioned, tightened 2 setscrews. Problem solved.
    1998 machine brake is part of motor assembly. Will Be Sending Out to local electric motor repair shop for evaluation when workload permits.
    Apr 2009
    1262
    Re: X axis brake
    They have a tendency to get coolant mist build up on them and then slip because they are "greasy". A good cleaning will typically give you more life. Design was changed to internal to protect from mist.
    Eventually they will wear out from use. Every time the e-stop is pressed or the machine is turned off the brake activates to keep the turret from dropping.
    Best regards,
    Experience is what you get just after you needed it.
  1. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  2. Z-Axis Brake? Huh?
    By firstyear in forum Servo Motors / Drives
    Last Post: 09-08-2011, 06:44 AM
  3. Z Axis Brake? Huh?
    By firstyear in forum CNC Machine Related Electronics
    Last Post: 09-03-2011, 12:22 PM
  4. Z-axis Brake
    By Ben Colby in forum CamSoft Products
    Last Post: 01-24-2011, 09:49 PM
  5. A axis brake issue
    By nervis1 in forum Post Processors for MC
    Last Post: 04-18-2006, 02:46 AM
