Quote these in lots of 12 and 24. The 1st order will be for 12. This may be a steady job for someone once i get things rolling. The material is 6061 Aluminum and you are to supply it. I forgot to include the surface finish on the drawing. all the bore finishes and OD are 125, the faces (only the ends of part) are 63.
I have made these before on a Mazak lathe and it was pretty easy with regular steel boring bars if you get the speeds right. Its really not that hard to do because its just aluminum. These took me 10 minutes each
send your quotes to [email protected].... Please include delivery time once ordered
Some of the text in the drawing ran together because it was drawn in mastercam and then converted over to dxf.
