586,430 active members*
4,099 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Fusion 360 4th axis indexing not working correctly.
    Jan 2012
    58
    Has anyone successfully used Fusion 360 to do 4th axis indexing on a Tormach / PathPilot PCNC 1100?
    I'm using Fusion 360 on an iMac to generate G-code for my Tormach PCNC 1100, with a PathPilot controller (using the Tormach PathPilot Post Processor downloaded from Tormach's website). The Post Processor has been edited to enable 4th axis (changed "false" to "true" @ line 127), and it successfully generates G0 A-axis code as needed.
    The problem is that the X-Y-Z coordinates generated do not acknowledge that the A axis has been rotated.
    Example: I modeled a rectangular block, mounted lengthwise into the A-axis rotary table. I want to to a 2d face operation on all 4 sides of the blank. I set it up per the examples I found online, changing the orientation for each successive operation, and using the same center endpoint as the origin. The simulation looks exactly as expected, however the G-code generated is goofy.
    Once it has successfully faced the first (0 deg) face (using a zig-zag pattern in the X-Y axis), it rotates the A axis 90 deg (as expected), but then the code directs the facemill to zigzag up and down in the Z-X axis, as if the blank had not rotated by 90 deg.
    I'm stumped. This is a pretty basic application of A axis indexing (which F360 supposedly does well), and it does not work.
    I have struggled with this for several days now; the Autodesk forum is presently in read-only mode for a conversion of some sort, and I am stuck.
    Surely I'm not the only Tormach user who has attempted to do 4th axis indexing with Fusion 360? Help!
    Sent from my iPad using Tapatalk
    Nov 2010
    291
    Re: Fusion 360 4th axis indexing not working correctly.
    While not 360 Autodesk Inventor doesn't support 4th axis positioning. Not sure how much the programs are related.
    Sep 2009
    1856
    did the advice you received help on the Fusion forum
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Jan 2012
    58
    Quote Originally Posted by daniellyall View Post
    I received the following response to my post on the Autodesk forum:
    "That sounds like the post processor you are using assumes you have tool center point control enabled on the machine"
    Sounds helpful, might even correctly identify the problem that I am having, but I have no idea what it means, or what to do about it. I posted a response, requesting more info - hopefully someone will follow up.
    Does anyone else out there have any experience using Fusion 360 to generate 4th axis indexing operations on a Tormach machine?
  1. Rotary Indexing Not posting correctly.
    By blakemachine in forum Mastercam
    Last Post: 08-29-2012, 09:05 AM
  2. Goround not working correctly
    By dlenardu in forum Dolphin CAD/CAM
    Last Post: 09-03-2011, 07:03 PM
  3. G02 and G03 not working correctly
    By Aircraftman in forum G-Code Programing
    Last Post: 07-18-2009, 06:04 PM
  4. Z Axis is not working correctly.
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 09-22-2008, 03:29 PM
  5. Encoders not working correctly
    By ozturbo in forum LinuxCNC (formerly EMC2)
    Last Post: 08-06-2008, 03:44 PM
