586,043 active members*
3,696 visitors online*
    Feb 2016
    Benbox and DIY Laser Cutter
    HI All,
    I am another newbie trying to use a laser engraver for my new business burning my logo onto wooden objects.
    I have purchase a 'cheap' chinese 1600mW DIY desktop blue laser engraving machine from ebay with no instructions or software.
    After a bit of searching it seems that Benbox Laser engraver is the standard software to use, but again no instructions other than looking on the forums to see what other people use for settings.
    I have tried several different settings but the engravings / burns are really bad.i know this because i also purchased an even cheaper small engraver with software and it works perfectly, its just too small for my needs.
    I was hoping someone might be able to advise what settings are needed to burn my logo onto soft wood, using .png jpg images.
    I have attached some images of the settings i am using along with the result .
    Any advice would be really appreciated
    Many Thanks
    Attached Thumbnails Attached Thumbnails 2016-02-14_201629.jpg   2016-02-14_201615.png
    Mar 2012
    23
    Is it properly focused for the height of the wood you're using?
    Feb 2004
    361
    Re: Benbox and DIY Laser Cutter
    you could try speed 800 to 1100, timing 4 to 7, 7 is hotter, and scan by line has better reseloution than scan by Z
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2020, 02:14 AM
  2. My chinese laser cutter won't work at all, software doesn't see the cutter
    By Sasa1234 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-01-2019, 04:09 AM
  3. New Forum For Benbox China Laser
    By rfresh737 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-29-2016, 04:31 AM
  4. 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
    By ecpur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 08:23 AM
  5. CNC Plasma Cutter, Laser Cutter, Water Jet
    By antsals in forum Waterjet General Topics
    Last Post: 03-11-2011, 01:56 PM
