587,070 active members*
3,084 visitors online*
Results 1 to 11 of 11
    May 2006
    143
    Newest PP Fusion360 post.
    Can somebody upload the most current generally accepted fusion 360 post for PP. Is there a generally acccepted as "best / most problem free" post right now?
    Im running a turret and gang. The autodesk cam forums are undergoing maintenance right now and wont allow me to make an account in order to download from there.
    Jesse
    Re: Newest PP Fusion360 post.
    Jesse,
    Would like to help, but I'm in same boat.
    Something to be aware of ... I was at the Anaheim Convention Center last Thursday for the annual ATX show.
    I met with a representative form Autodesk and mentioned that I just got a Tormach Lathe ... he said be sure to get the
    "code from Tormach" that gives you PP for free the1st year.
    So I will be calling them Monday to check into that.
    Later,
    Pat H
    Jul 2004
    1424
    Of course,Fusion360 is free forever (until they change their minds) to hobbyists and startups who gross less than $100k/year.
Name:	Screen Shot 2016-02-14 at 2.39.05 PM.png
    I am assuming you are looking for Adam's post from this thread:
    https://camforum.autodesk.com/index.php?topic=7481.150
    pm sent; check your messages.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Thanks for the link ..
    I guess the rep wasn't up to date, I have heard that it was free on several boards, but he seemed sure of himself.
    So thanks for the clarification.
    Pat H
    May 2015
    111
    Here is the post I am using. It is by Adamvs99 from the autodesk cam forum.
    The post is working great for me. I am using both the turret and gang tooling.
    Had to share it on dropbox, I could not figure out how to upload it.
    Chris
    https://www.dropbox.com/s/u490qlzuqa...0.cps.zip?dl=0
    May 2006
    143
    Thanks guys!!
    Sep 2009
    1856
    Adamvs99 post is the only one that is tested by a few so is known to work well, you will have to weight to the HSM forum is up to let him know of any problems unless he has moved to the fusion cam forum.
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Jun 2006
    3063
    For you Fusion360 usewrs - does F360 simulate both the the turret and cross slide moving as different ops are machined?
    May 2015
    111
    It just shows the tool, not the machine.
    Jun 2006
    3063
    Too bad - in my brief explorations so far there are scenarios where there could be interference between the work or chuck and a turret tool when a gang tool is cutting or vise versa.
    Oct 2010
    253
    Quote Originally Posted by daniellyall View Post
    I'm a bit late to this thread, just found it last night. I'm maintaining the latest on GitHub you can find it here - in the 'src' directory:
    SlantPro post processor-Fusion, HSM
    One feature that saved my butt the other day was being able to import a section of hand coded gcode from a file so you don't have to copy and paste it in every time you do an iteration on the part. In this case it was a face groove for an o-ring - ( a pretty easy thing to hand code but Fusion has no direct way to do this .. the examples on the internet are horrible kludgy workarounds .. which I could not get to work anyway in the latest Fusion update.
  1. Tapping in Mach3 with Fusion360
    By Jkurtis in forum Mach Mill
    Last Post: 06-19-2019, 12:41 PM
  2. Fusion360 Ultimate _ Cloud storage?
    By Black Forest in forum Autodesk CAM
    Last Post: 07-29-2015, 05:22 PM
