586,114 active members*
3,179 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mach3 + C35 BOB + Coolant control= Hair Loss
Results 1 to 10 of 10
    Aug 2015
    14
    I’m trying to control my coolant in mach3 with a solid saterelay from my output pins and have been unsuccessful so far.
    I have Output Pins 1, 14 16 and 17 active in Mach3
    Output 1 Port 1 Pin 1
    Output 14 Port 1 Pin 14
    Output 16 Port 1 Pin 16
    Output 17 Port 1 Pin 17
    I have check and unchecked active low settings on alloutputs.
    The only pin that produces power is pin 16 (5 VOLTS DC)
    With active low checked coolant comes on but wont cycle offwith Mach.
    With active low X coolant is off and wont cycle on withMach.
    I have the Disable Flood/Mist Coolant box unchecked
    I have tested the relay with another power supply to makesure it does work.
    Any sugestions?
    Nov 2009
    4415
    Re: Mach3 + C35 BOB + Coolant control= Hair Loss
    You are using a solid state relay?
    Do you have the AC and load connected? Assuming you are switching an AC load.
    If that is the case it needs to be connected.
    How are you asking to activate the relay? GCode?
    Do you have the proper assignment in Mach's spindle config?
    Also IIRC pin 16 is a charge pump.
    A lazy man does it twice.
    Aug 2015
    14
    Quote Originally Posted by Fastest1 View Post
    Thanks for replying.
    I'm using a solid state relay.
    I have the ac load connected.
    As of right now I'm using the MDI command M7 M8 and M9.
    That's helpful on the charge pump pin 16. Because the manual I have says 17. I couldn't get it to work so I just ran jumper back over to my enable pin.
    Nov 2009
    4415
    I am wrong in regards to pin 16. According to page 66 ITM 2-9, 1, 14, 16 & 17 are output pins.
    Though in reviewing your procedure, it all seems in place.
    Jan 2013
    630
    Do you have the options to disable the Flood/Mist relays checked in the Spindle Setup tab by chance?
    Aug 2015
    14
    I have the box unchecked.
    Aug 2015
    14
    thanks. I sent an email to cnc4pc. I'm just playing the waiting game now...
    Nov 2009
    4415
    I do notice 1 odd thing. You have an output 14, 16 & 17 enabled and assigned with the same number as the output pin. Looking at page 69 of the manual "engine configuration ports and pins, under spindle" regardless of spindle relay or mist/flood relay only outputs 1-6 are available. Which pin is your relay wired to?
    Dec 2014
    46
    I am having a similar problem, have you resolved the issues with the solid state relay and the coolant?
    Sep 2017
    53
    old thread bump ....
    resolution? dont leave me hangin bro
  1. Coolant Pump Pressure Loss
    By l u k e in forum Haas Mills
    Last Post: 02-15-2014, 08:54 PM
  2. Flood Coolant Loss Rate....
    By SCzEngrgGroup in forum Tormach Personal CNC Mill
    Last Post: 10-27-2011, 11:49 AM
  3. loss of z axis control
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 01-17-2011, 09:10 PM
  4. How to control the water coolant by mach3?
    By Mongkol in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2010, 10:06 PM
  5. Loss of low power control. Any suggestions
    By Strelitzia in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-16-2008, 09:56 PM
