586,329 active members*
5,205 visitors online*
Results 1 to 3 of 3
    Sep 2015
    29
    Cutting Does not start where I Zero/ref the machine
    Hi, I'm having an issue where I have a small piece of material say 12"x12" and my part is 11.5"x11.5"
    I Ref all home and zero in the bottom corner of the material, but mach has my table work area offset slightly so the start point is not at 0,0 (x,y) in reality it starts cutting at ~ 2,2 (x,y)
    is there a way to change this? I cant find the setting, and I looked in sheetcam also.
    here is pictures of what I am talking about. It is visible on the mach3 table display box - shows the table as a dashed grey line.
    35538
    Re: Cutting Does not start where I Zero/ref the machine
    Set your X and Y offsets to zero.
    Sep 2015
    29
    Thank you, I had to change values in Homing and Limit config.
    I missed that before
  1. best choice steel sheet cutting machine fiber 500w laser cutting machine
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-22-2015, 08:46 AM
  2. Replies: 0
    Last Post: 06-02-2015, 07:53 AM
  3. Replies: 0
    Last Post: 05-20-2014, 09:46 AM
  4. Replies: 0
    Last Post: 12-18-2013, 08:08 AM
  5. Replies: 0
    Last Post: 11-28-2013, 08:01 AM
