586,094 active members*
3,993 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Why isn't my gcode running??
Page 1 of 2 12
Results 1 to 20 of 30
    Oct 2007
    446
    Question Why isn't my gcode running??
    Not sure why its not running...using mach 3. This line flashes red in the readout and then nothing...just sits there...
    (TOOL #1 0.25 1/4 2 Flute LOC 1.125)
    any ideas?
    O100 (PROGRAM NUMBER)
    (BEGIN PREDATOR NC HEADER)
    (MCH_FILE=4AXVMILL.MCH)
    (COORD_SYS 1=X0 Y0 Z0)
    (MTOOL T1 S1 D0.25 C0. A0. H3.)
    (SBOX X-1. Y-7.1875 Z0. L6. W8. H0.75)
    (END PREDATOR NC HEADER)
    (FIRST MACHINE SETUP - Machine Setup - 1)
    (PROGRAM NAME - DUSTBOOT_TOPPLATE.TAP)
    (POST - BC_3X_MILL 3-AXIS GENERIC FANUC)
    (DATE - SAT. 02/13/2016)
    (TIME - 03:48PM)
    N01 G00 G17 G40 G49 G80 G20 G90
    (FIRST CUT - FIRST TOOL)
    (Machine Setup - 1 Facing)
    (FACING)
    N02 G90 G54 X-0.551 Y0.3 S1222 M03
    N03 G43 H1 D1 Z1.75
    N04 Z0.95
    N05 Z0.85
    Jun 2014
    777
    Re: Why isn't my gcode running??
    Your using a fanuc pp, try using a generic Mach 3 pp.
    Oct 2007
    446
    ....seems to be finicky...sometimes it works and sometimes doesn't. I have to open and close mach, reload file and run it again until it works...
    Quote Originally Posted by airbrush View Post
    Ask on the Mach3 support forum, the guys there are as pleasant and helpful as those here,
    Regards,
    Nick
    Oct 2007
    446
    will have to verify this...but seems like if i start mach and immediately load a gcode file then it works.
    This morning loaded up a file, zero'd everything cycle start..nothing. Close mach, load file, zero, worked fine....
    Jun 2008
    1838
    That would seem to indicate the screenset has a stability issue,have you thought of trying out Mach4 or the Calypso Ventures (Calypso Ventures, Inc.) screenset,($69 USD) that does tool offset probing and is a nicer screen IMHO, I have it on a 3x Mill that has an ATC and I can just fill the carousel with tools and run a small toolchange program and it will go through all the tools one by one and set the length offsets in the tool library for me, takes a few minutes and they are all done ready to be called by the program as required.
    I have/can do one tool at a time just by using the MDI and inputting say T2 M06, that triggers the software to do the touch off for the tool.
    Worth a look anyway
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Oct 2007
    446
    okay will try....
    I've ran a couple other small parts using this post processor no problems....
    what would be the difference between fanuc and mach 3?
    thx
    Jun 2008
    1838
    thx
    There is no difference between Fanuc and Mach3, Mach3 is based on Fanuc ISO G code so that is unlikely to be the issue, that line is in brackets so should be ignored by Mach3 anyway
    Your code runs fine in both Mach3 and Mach4 here, must be something in your Mach3 setup that has changed somehow, I would check out your General Config first
    Regards
    Rob
    Oct 2007
    446
    also forgot to mention i'm using 2010 screenset for mach3...will have to go through all of my settings and check. Will load up my other files that i already cut and see if those go too..Don't remember touching anything in there other than manual spindle change and ignore m6 calls....
    thx
    Jun 2008
    1838
    I think it may be that particular screenset, I have just tested your code on 4 different Mach3 screensets and 2 different Mach4 screensets and it works on all of them, next I tried the 2010 screenset and I get the same issues as you so try a different screenset, the default 1024 screenset would be a good place to start, I found the 2010 one to be unstable and that was on a PC with XP Pro 32 bit OS which runs anything and everything
    Regards
    Rob
    Oct 2007
    446
    hmm...well that would not be good...got the 2010 screenset to make manual tool changes easier...maybe i'll post this over in the screenset thread....
    Jun 2008
    1838
    Not sure I am following you, why would you specifically need the 2010 screenset to be able to do manual toolchanges ?
    I would always have that done in the PP, here is a typical set of code showing the end of one feature and the start of the next one with a different tool, I know this runs in Mach3, I use it every day
    This is all in Metric
    N360 Z30. Head moves up to rapid clearance
    N370 G40 Cancels any previous offsets
    N380 M09 Coolant off
    N390 M05 Spindle stop
    N400 G91 G28 Z0. Moves head up to machine Zero position
    N410 M00 Stops machine
    Now the manual change can be safely done with the head at the top of it`s travel
    Now just press "Cycle Start" to resume cutting with the new tool
    (Machine Setup - 1 Profile Finish)
    (PROFILE FINISH)
    ( TOOL #2 - 8mm Flat End Mill 4Fl Carbide)
    N420 T02 M06
    N430 S4000 M03
    N440 G90 G54 X-10.54 Y10.233
    N450 G43 H02 Z30. M08
    If your PP doesn`t do this and you would like it to then upload it and I or someone will tweak it for you to just how you need it, all the above is assuming you are running a 3 axis machine
    Regards
    Rob
    Oct 2007
    446
    the 2010 screenset will zero your new tool to a mounted touch plate on the machine once its changed. Just automates everything and makes it a little easier.
    for example...doing a rough pass with a 1/4 endmill then a finishing pass with an 1/8 ball mill....it compensates for the different lengths of the tool.
    I use ER11 collet chucks on 10mm straight shanks for everything up to 7mm, that gives me repeatable tool lengths allowing me to populate the Mach3 tool table.
    I started off with 4 and set them up for each job but it proved such a handy system I'm keeping an increasing number of tools permanently set up that way,
    - Nick
    Jun 2008
    1838
    Don`t you have the tool lengths already set in your tool library ? ?
    Ahh, sorry, I take it you are changing collets and cutters in the spindle, not using cutters in separate tool holders, if so then yes, you are stuck with trying to use the 2010 screenset, tough one that
    I have all my cutters in toolholders, I got adapters for my spindles so that I could use the "Easychange" system instead of the original R8 setup, I probably have around 40 holders I have built up over the years
    Sorry I couldn`t be of more help to you
    Regards
    Rob
    Oct 2007
    446
    Newbie here....i have a home based router machine. If it is indeed the screenset throwing things off then that really throws a stick in mud for me...
    I'm sure there are a lot of Mach3 users doing very similar things, the official Mach3 forum (Machsupport Forum - Index) in the General Mach Discussion is the ideal place to ask what others are doing and what solutions there may be, including your Mach3 version will help as there are specific versions with specific issues and older versions are available to download should that prove to be the solution to your problem,
    Regards,
    Nick
    Oct 2007
    446
    Okay...well thats painless then...i assumed i would have to uninstall the current version first....
    35538
    The screenset should have no effect on the g-code at all. It doesn't have any effect at all on how Mach3 runs. The only thing the 2010 Screenset does differently than a stock screen is the M6 macros.
    You might want to try copying the stock M6Start and M6End macros with the 2010 Screenset and see if it works.
    If you send me the entire g-code file, I'll take a look at it this evening.
    I've just done a test of a full install of the suggested older version over a working existing later version on a Windows 7 machine and can confirm that all settings and license are still in place and the machine works perfectly.
    I did back up the whole Mach3 folder plus screenshots of all config pages, as you should, but in this instance everything worked just fine.
    It's easy to be brave when you have a full clone of your PC sitting on the shelf ;-)
    - Nick
Page 1 of 2 12
  1. X3 Mill running mach 3-skipping steps during Gcode? not during jog
    By gonetowin in forum Mach Software (ArtSoft software)
    Last Post: 02-02-2015, 08:19 PM
  2. Precix running with Mach3 gcode, problem in edges and corners
    By FABLABBARCELONA in forum Commercial CNC Wood Routers
    Last Post: 12-29-2014, 05:49 PM
  3. Replies: 1
    Last Post: 05-28-2013, 04:25 AM
  4. Bridgeport Conversion (Which kit is best for just running imported gcode?)
    By ronderkis in forum Bridgeport / Hardinge Mills
    Last Post: 04-04-2013, 01:02 AM
  5. Running a gcode output file in the computer
    By Palafox in forum Uncategorised CAM Discussion
    Last Post: 06-10-2008, 11:56 PM
