586,071 active members*
3,920 visitors online*
Results 1 to 9 of 9
    Jan 2016
    4
    AutoLaser not working properly
    Hello
    I bought a RedSail x900
    and its been nothing but issues thus far....
    currently i have it working to the point where it can now cut wood
    but the issue is now Autolaser doesnt seem to want to open any AI or CDR files
    redsail support advised to use Coreldraw output but even that wont work properly... i get
    Runtime Error 5
    Should I be using different software other then autolaser? if so which one would work best?
    Please any help would be appreciated
    Re: AutoLaser not working properly
    Hi ,you can visit Autolaser software company website and download new software.
    http://www.topwisdom.com.cn/en/index.asp
    Good luck!
    Quote Originally Posted by dwagar View Post
    Hello
    Runtime Error 5
    Jun 2015
    Good luck with the installing the Corel Plugin. And good luck with getting any help from China. Easiest way to go from Corel to the Autolaser software is to simply export your file as a .plt (plotter) file from Corel. Once you have your file in autolaser you can set the power and speed setting from there.
    May 2016
    30
    Hello
    Runtime Error 5
    What ??? No answer in 4 months????
    Yakkk I just bought and are still waiting for a M900 so I will maybe get tha same problems, and I dont even have Corel Draw. I'm using Illustrator.
    You are writing that you now can cut wood. So what have you done so far to get to that?
    Jun 2015
    It only works properly if you export your corel files as a .plt (plotter) file. Autolaser will read .plt files correctly.
    Hi dear ,
    Did you install the new version Autolaser software?
    And you must sure you install the software correctly .Please check the attachment of hoe to install the software with coreldraw .
    By the way ,where did you bought X900 laser machine?
    Hello
    Runtime Error 5
    Jan 2016
    4
    Quote Originally Posted by Klausm2 View Post
    I havent used it in a few months (been out of the country)
    but its been more work then I anticipated,
    First off if your in a western country and they try to "convert" your laser to 110 vs their 210 dont do it
    the laser bulb does not get nearly enough power,(I couldnt even cut cardboard)
    another issue is the bed doesnt work, the cutting bed is 900x 600 and it wont use the whole bed (only will use 300x600
    ive played with the settings and it seems a probelm with the programming
    So far im unimpressed... ive worked with the team and while they try to help i still can not get it running 100%
    I did get the corel draw plug in to work though, after some fiddling with it, illustrator not so much
    ALTHOUGH if you do get corel draw DO NOT GET 7 it does not work with that program (after working with one of their techs who remotely connected to my computer)
    Good luck
    Oct 2016
    I just purchased a RedSail X900. I have assembled the machine and aligned the laser. I NEED help getting started. Creating a simple file, outputting the file, and engraving the file. Don't have much money, but I am willing to pay for your time, assistance, and any knowledge you can share. I have attached the control pad on my machine. I am a software guy so a very quick learner. I figure out the rest if I can just get it started.
    Quote Originally Posted by lsrman View Post
    Hi dear,who sell X900 laser machine to you ? Did you contacted the seller before ?
    And did you have the software and could you see the software manual i upgraded before?
  1. CANNOT get pci-e parallel port working properly *freezing*
    By jayrod7387 in forum Mach Software (ArtSoft software)
    Last Post: 02-02-2016, 05:00 AM
  2. Trouble getting my table working properly
    By austin.mn in forum Waterjet General Topics
    Last Post: 08-26-2010, 04:18 AM
  3. TOOL CHANGER ON VMC NOT WORKING PROPERLY
    By prash in forum Uncategorised MetalWorking Machines
    Last Post: 04-09-2010, 05:46 AM
  4. Lazycam Not working properly for me?
    By jstevens in forum Machines running Mach Software
    Last Post: 07-06-2007, 08:00 AM
  5. Replies: 1
    Last Post: 10-20-2006, 05:05 PM
