586,094 active members*
4,021 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Bobcad V27 "nc file path" won't stick
    Feb 2006
    15
    I set a path under Milling Job/ Current Setting /Posting and it will not stick. The post (nc code) is saved where Bobcad wants it to go . This happens after I change the post processor. I've tried saving the .bbcd, closing and reloading Bobcad, etc. Is there a way to make the nc file path permanent?
    Jun 2008
    1838
    Re: Bobcad V27 "nc file path" won't stick
    Have you set it under "CAM Defaults > Current settings > Posting" to be the default, if not go to there and set the file path, then go to the "Machine Parameters" tab, double check that all the settings there are as you want them (rapids, max feeds etc) and if all OK then ckick the "Save as a Default" button.
    Important, now close BobCAD and re-open it and the settings should have "stuck"
    Every time you open V27 it will have those settings, if you change a PP in a Milling Job the NC file path should not change.
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Jun 2006
    143
    I have a question related to this. I have my default post processor set for my milling machine, but is it possible to set one for a lathe as well? When I go under "CAM Defaults > Current settings > Posting" I see my mill post listed, and there is no place to select a lathe default post. Any ideas?
    Feb 2006
    15
    Malish: as best I can tell you should open a new machining job (V27). FILE NEW / MACHINING JOB / TURNING / SELECT MACHINE. I only see one machine: BC_2x_Lathe. And I have not played with the lathe function yet.
  1. Replies: 4
    Last Post: 02-11-2015, 03:44 AM
  2. EZ PATH S: STRANGE MACHINE LIMIT PROBLEM (what is the mystery "9")
    By Cortazar in forum Bridgeport / Romi Lathes
    Last Post: 12-27-2014, 06:46 PM
  3. Replies: 8
    Last Post: 05-11-2014, 09:15 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Need to make "sphere on a stick"
    By kns1313 in forum MetalWork Discussion
    Last Post: 04-14-2007, 04:02 AM
