586,103 active members*
3,497 visitors online*
    Nov 2010
    65
    Batteries in Cincom L25, with Meldas 500?
    Hi.
    I have recently aquired a Cincom L25 with a Meldas 500 control from 1996.
    Now my question is, does this machine need to have the batteries changed? It has a battery unit called MDS-A-BT-6. If it needs changing, how often? Also, does it have other batteries I need to worry about? I was told to look inside the control if there was one, but I'm not seeing it if there is.
    Thanks all
    Jan 2012
    19
    Re: Batteries in Cincom L25, with Meldas 500?
    Hi Lene,
    You should change the battery unit our every year.
    To be safe, you should also backup the control parameters from the Data screen using your RS232 connection.
    Pete
  1. Need Mitsubishi Meldas 320' parameters for Cincom L16
    By Nickon59 in forum Mitsubishi controls
    Last Post: 10-03-2023, 05:06 PM
  2. Parameters for Citizen Cincom L16 With Meldas 320 CNC control
    By IvCastilla in forum CITIZEN Machines
    Last Post: 11-24-2022, 02:38 PM
  3. Back up batteries
    By MazakMack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-04-2013, 09:50 PM
  4. Batteries
    By underthetire in forum Okuma
    Last Post: 11-10-2011, 09:38 PM
  5. Memory Batteries AM1
    By greenchair in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2008, 07:42 PM
