586,075 active members*
4,075 visitors online*
    Question MR-J2-CT Software failure on Mazatrol 640MT
    Hello everybody.
    I'm experiencing an issue on a Mazatrol 640MT fitted on an Integrex.
    Previously I had a Hard disk drive failure. I've fixed it by replacing a SMD fuse on the HDD PCB.
    I've made a ghost backup of the HDD. And try to restore it to a new one but doesn't work.
    So problem was solved, everything works fine. OK. Next =>
    Few months later, battery alarm.
    Replacing it by a rechageable battery 110mAh (bad idea!) no recharge circuit in the HR083 board!!!
    So replaced by a lithium battery 2Ah.
    But I had to restore all parameters via tool in "Mainte" folder.
    OK ok
    BUT a remaining failure on the ATC (Tool changer) exist. Because of home is not set!!! Normal for the moment.
    So, I want to open MR-J2-CT-M6 Setup S_W but it's impossible. It answer me "The installation did not end normally" and close.
    I'm not able to reinstall it and ghost copy doesn't work better.
    Do you have this software?
    FWS-B05B015 (BUS CONNECTION)
    Do I need another file or program installed with? I've seen VBRun300.dll file inside the J2CTBUS.
    I've found the J2CTCOM software but I need the M6 one
    Many thanks for your help or suggestions. :wave:
    Re: MR-J2-CT Software failure on Mazatrol 640MT
    I've found the manual for the software
    http://dl.mitsubishielectric.com/dl/...2208(eng)Z.pdf
    They speak about the bus version that I need to restore or repair.
    If someone has the disk they tell???
    Comm RS232 version is available on this thread.
    http://www.cnczone.com/forums/mazak-...-software.html
    Service Procedure by following this link =>
    http://www.sparshatts.com/sites/defa...Fusion_640.pdf
    Thanks again.
    Nobody can help?
    UP
    May 2019
    I have this software.
    [email protected]
  1. 5 Axis programming Mazak 400 III Mazatrol 640MT PRO
    By ProToZyKo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-18-2014, 08:32 AM
  2. Language change on mazatrol 640MT
    By pharaon80 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-27-2012, 09:28 PM
  3. Integrex with Mazatrol 640MT
    By Patrickcrossan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-12-2012, 02:07 PM
  4. g128 Macro 640MT PRO control
    By nitrosnfr in forum G-Code Programing
    Last Post: 05-17-2007, 05:56 PM
  5. New software for Mazatrol
    By psevin in forum News Announcements
    Last Post: 03-09-2006, 08:17 PM
