586,493 active members*
2,145 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Set-of-3-400W-Panasonic-AC-servos-with-drivers
Results 1 to 6 of 6
    Sep 2011
    474
    Re: Set-of-3-400W-Panasonic-AC-servos-with-drivers
    Do those motors have 1/2" shafts?
    Sep 2011
    474
    These come with 14mm shafts, which works out to just over .55".
    Cheers,
    Are the bosses on the front of the motors 50mm? That's what size I need for my planetary gearboxes. The 14mm shaft is also what I need. I need it to fit in one of these:
    New in Box Harmonic Drive Systems HPG 20A 21 J6GCK Planetary Gear Reducer | eBay
    Also, do they accept step and direction?
    Two days earlier I may have bought them for sure, but I bought a new laptop the day before you listed them, and my funds are limited right now.
    Sep 2011
    474
    Bosses appear to be 36mm. Im not sure if these support step/dir since im using global closed loop Linux with my (slow) build. Here's a full manual to flip through if you want to get a better idea of what these are capable of and compatible with. Im sure someone over in the Servo forum has a way to control these via step/dir.
    https://industrial.panasonic.com/con.../minas_s_e.pdf
    I already looked through the manual yesterday.
    The 36mm is a no go for me. Sorry.
  1. Master-Slave configuration Adtech-panasonic servos
    By b33felix in forum Servo Motors / Drives
    Last Post: 12-14-2015, 01:56 PM
  2. Replies: 6
    Last Post: 11-20-2015, 07:11 PM
  3. Replies: 0
    Last Post: 01-05-2013, 11:51 PM
  4. panasonic servos
    By dreammstr6 in forum Bridgeport / Hardinge Mills
    Last Post: 01-13-2011, 11:30 PM
