586,067 active members*
5,239 visitors online*
    Oct 2007
    1024
    vac puck used on an adjustable clamp
    used a vac puck on a adjustable clamp that was used for holding bird carving blanks
    works quite good , its a good addition to vac hold downs in a small shop and is cnc built
    https://youtu.be/Gu0GSpjGu0s
    the o rings come from lee valley tools a package of 3
    Nov 2014
    20
    Re: vac puck used on an adjustable clamp
    Impressive. I would like to make a few of those myself. Would you be willing to share your file?
    Sent from my SM-G930P using Tapatalk
  1. Building Vacuum Clamp and Mechanical Clamp Sub-Table
    By automizer in forum DIY CNC Router Table Machines
    Last Post: 04-27-2012, 06:46 PM
  2. digitizing from paper with a puck.
    By mvcorrea in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-26-2008, 03:08 AM
  3. Building Vacuum Clamp and Mechanical Clamp Sub-Table
    By automizer in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-08-2008, 03:05 AM
  4. Rubber hockey puck?!
    By abomb55076 in forum Material Machining Solutions
    Last Post: 02-27-2008, 06:56 PM
  5. tablet puck as pendant?
    By foamcutter in forum CNC Machine Related Electronics
    Last Post: 03-04-2005, 01:32 AM
