586,069 active members*
3,714 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Fanuc-0 BUF - Spindle Runs, Tool Homes, Then Stays
Results 1 to 10 of 10
    Feb 2016
    5
    Hello,
    Please excuse a theoretician gracing himself in the world of machining but we have an Emco Turn 50 with code generated from InventorHSM. As it's our first run, it's a simple end knock down of a 3/4" delrin round stock. We set work shift, tool shifts, and upload code. We dry run, and the code looks good. BUT, we run without dry run mode and it locks up on a G0 command right at the tip of the piece. Here's the code. Mind you, InventorHSM wants to provide G54 command but WCS is not on this machine (that I know of-it throws an invalide Gcode command). As far as I can tell it hangs up on N21.
    Code:
    O1015 (34 STOCK)
    N10 G90 G95 G18
    N11 G20
    N12 G92 S6000
    N13 G28 U0.
    (PROFILE5)
    N14 T0202
    N15 G94
    N16 G97 S1000
    N17 M3
    N18 G0 X1.4588 Z0.1969
    N19 G0 Z0.0409
    N20 X0.7846
    N21 G1 X0.7202 F0.004
    N22 G18
    N23 G1 G42 X0.6071 Z-0.0156
    N24 Z-0.4572
    N25 G2 X0.6714 Z-0.4731 R0.085
    N27 G1 G40 X0.7846 Z-0.4165
    N28 G0 Z0.0409
    N29 X0.6559
    N31 G1 G42 X0.5428 Z-0.0156 F0.004
    N32 Z-0.3906
    N33 G2 X0.6471 Z-0.469 R0.085
    N35 G1 G40 X0.7602 Z-0.4125
    N36 G0 Z0.0409
    N37 X0.5759
    N39 G1 G42 X0.4628 Z-0.0156 F0.004
    N40 Z-0.3906
    N41 G2 X0.6714 Z-0.5139 R0.125
    N43 G1 G40 X0.7846 Z-0.4573
    N44 X0.8222
    N45 G0 X1.4588
    N46 Z0.1969
    N47 G28 U0. W0.
    N48 M30
    Feb 2006
    1792
    Re: Fanuc-0 BUF - Spindle Runs, Tool Homes, Then Stays
    This code is not in G-code system A. It is in B or C. Most lathes are set to use system A. You would need to study your machine manual to find out what it needs.
    Dec 2008
    3109
    What controller does it have ?
    A quick goggle indicates a possible Fanuc
    - it is only a lathe, yes ?
    then explain the g-codes you use ie G94,/G95 as these are milling codes for feed control, lathes use G98/G99
    - also look at the tip offset direction (0-8) when using cutter comp as this is a b?tch to get correct
    use single step to find the offending line ( or lines ), as the error could be reading ahead.
    ( to see if cutter comp is giving the problem, remove the G42, & see if it runs )
    ( make sure your retracts allow for the comp cancellation moves )
    Feb 2016
    5
    Hi and thanks for the responses. Yes, I should have said Fanuc 0, just a lathe. However, I believe it to be Type B or C as the documentation I have on it specifies G94 and 95 as feed rates and G98 as return to start plane.
    Feb 2006
    1792
    Change it to system A; otherwise nobody would be able to help you. Very few people use B or C.
    Feb 2009
    6028
    Don't think it's locking up, I think your in feed per minute (g94) with a feedfrate programmed in inches per rev, so it's just going reallllly slow.
    Sent from my A3-A20FHD using Tapatalk
    Feb 2016
    5
    Quote Originally Posted by underthetire View Post
    Wow, I think you're right. I'll take a look when I'm in the lab next. The funny thing is that the dry run "looked nice" but apparently it's not compensating for the feed rate in that mode. Thoughts? Thanks!
    Feb 2009
    6028
    Dry run is in in inches per minute usually, that way you can dry run without the spindle rotating.
    Feb 2016
    5
    Good point. I think this will get us on our way. Definitely been a learning experience. Thank you.
    Feb 2016
    5
    This solve our problem... thanks again.
  1. J310 spindle stays on after program run
    By ken fedirko in forum Tree
    Last Post: 12-03-2013, 06:42 AM
  2. Replies: 9
    Last Post: 06-21-2012, 05:47 PM
  3. Replies: 9
    Last Post: 03-22-2008, 05:44 AM
  4. Fanuc 0M stays in MDI mode
    By malaron in forum Fanuc
    Last Post: 08-06-2007, 11:19 PM
  5. Fanuc 15-M... Spindle Off lamp stays ON
    By cncnovice in forum Haas Mills
    Last Post: 05-11-2006, 03:04 PM
