Hi forum,
I just want a simple program where I can control the axis/ test to see if it is functioning.
Turbo CNC tends to lock up in Win Xp. Does anyone know a more simplier program ?
Hi forum,
Live life like you never see another day
You will need DOS to run turbo, not MS DOS mode or command prompt in Win98/95/2000/XP, real good ol' DOS. If you have an old win95/98 box, you can simply keep pressing F8 at startup, about the time you press del to enter bios, and at the menu that comes up select command prompt only. This will give you DOS and not much else. Start turbo and away you go, probably best off pressing F8 which brings up the jog screen, and use that.
Either that or download Mach and install that, I haven't used it so I can't give any advice on it, but I'm sure someone will post something here.
Russell.
you may be able to use the xp install disc and at the first menu choose quit.
Try the demo download of Quickstep,
http://cpwojcik.home.att.net/Qstep/Page_6x.html
or just download Mach and use it.
both of these work with Xp.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
