A manufacturer of components for a variety of applications is currently seeking a CNC programmer to join their staff in the greater Detroit area. The CNC programmer will write codes to instruct the CNC machines. This position would be a great role for a machinist or programmer with several years of experience working with mills and lathes. This position offers a competitive compensation package as well as benefits.
Overview: The CNC programmer will develop programs using G&M codes to meet the product’s specifications. The CNC programmer shall also assist machinists in training them with set-up and operation of the CNC mills and lathes. The CNC programmer will perform all necessary code changes to rectify and manufacturing errors.
CNC Programmer Job Opening
· Analyze engineering plans, blue prints, materials, specifications and other details to determine the proper tooling and coding for each job.
· Develop a program and upload it to mills and lathes manually at the machine, able to understand a write G&M codes from scratch. This will require basic math, geometry, and trigonometry.
· Perform machine set up, install and adjust chunks, attachments, tools, collets, and vices.
· Loads material into the machine for manufacturing.
· Check settings and specifications prior to running, and after the product has been machined.
· Observing and checking the machining to identify malfunctions or errors in the process. Able to identify coding problems and correct them promptly to minimize wasted materials or time.
· Ensures that all safety standards, rules, and regulations are followed within the shop. Notify proper supervision if standards are not met.
· Perform preventative maintenance on mills and lathes, notify proper staff of any malfunctions, and fill out the proper online form for repair requests.
· Able to utilize inspection equipment to verify machining specifications.
Job Requirements:
· A high school diploma minimum, associate’s degree would be beneficial.
· Demonstrated ability to understand and write G & M codes 3-axis mills and lathes, Fanuc controls experience would be beneficial.
· Able to understand complex mathematical concepts and formulas.
· Able to perform calculations necessary to make corrective actions to manufacturing processes.
· Ability to lift and load material into the machine.
· Good communication skills.
· Demonstrated ability to read blue prints, manuals, technical information, and business correspondence.
· A positive attitude, able to work with little direction for extended periods of time.
Please apply at: CNC Programmer Job Opening Detroit Michigan
