586,105 active members*
3,181 visitors online*
    Oct 2007
    446
    Question How to hold thin wood ply 1/16"
    just double back tape? I have some carpet tape i could use?
    What about cutting through...does it gum up the mill, pull up etc??
    -or just cut but leave a thin onion skin to hold it...?
    Jul 2003
    92
    Re: How to hold thin wood ply 1/16"
    You could use my binder-clip hold down:
    http://www.cnczone.com/forums/work-f...38500-cnc.html
    If you aren't going all the way through, though, it would be sub-optimum as thin material can move up/down in the middle which would impact pocketing depth.
    Sep 2013
    32
    You could use a down spiral end mill or maybe a straight flute and a vacuum table or perhaps the edge clips mentioned by CG. I have used double sided sticky tape and spray-on contact adhesive and both are a pain in the _ _ _.
  1. Recommend a laser cutter w/ at least 12"x12" cutting area to cut very thin plastics
    By Laserkid in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-28-2015, 02:27 PM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. best way to hold down thin stock on cnc mill
    By Smokey911 in forum MetalWork Discussion
    Last Post: 11-19-2012, 03:34 AM
  4. Best way to hold thin material for milling
    By toothandnail in forum MetalWork Discussion
    Last Post: 10-01-2012, 10:34 PM
  5. ring roll forge for thin wall parts, 1" to 4" OD
    By Arnaudb in forum Bending, Forging, Extrusion...
    Last Post: 04-23-2008, 11:01 AM
