586,061 active members*
4,412 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Design of a new hot wire cutter
    Feb 2016
    Hi
    I am in the process of designing a hot wire cutter that will have to cut a 2.5 metre width and up to 7 metre long caravan from polystyrene.
    The length is no problem but the width is as it will have the shape of a crescent moon.
    What I would like to know is:- is it possible to attach a wire at right angles to the cutting wire (most likely by means of soldering it)? Has any one done this? I am thinking of having the lower cutting wire suspended in several different places along its length with wires at right-angles holding it taught, A little like the cables on a suspension bridge.
    Do you think it might work?
    thanks
    Aug 2016
    35
    Re: Design of a new hot wire cutter
    Highly doubt it - post some pics or drawings of this project and perhaps I can advise
  1. DIY CNC Hot Wire Cutter
    By koko97 in forum CNC Wire Foam Cutter Machines
    Last Post: 11-07-2015, 02:15 PM
  2. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 10:15 PM
  3. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  4. RFQ. Wire design 3d
    By Builder in forum Employment Opportunity
    Last Post: 11-09-2006, 03:07 PM
