586,123 active members*
3,302 visitors online*
Page 1 of 2 12
Results 1 to 20 of 37
    Dec 2015
    23
    Steel Gantry CNC Milling Machine
    Hi everyone, new here and just wanted to post some photos of my on going milling machine project. Attachment 308964
    Attachment 308968
    I'm about 3 months into the build mainly weekends or any moment I can spare a few seconds. The main parts of the milling machine are done.
    Attachment 308970
    Attachment 308974
    Attachment 308978
    Attachment 308980
    Attachment 308984
    Attachment 308986
    Attachment 308988
    just finishing its base off, which after nearly completing the project, realized it should have been the first thing to do!
    Attachment 308990 Click image for larger version.
    Thoughts for the next project! Hope you like the pictures!
    Sent from my Nexus 5 using Tapatalk
    Mar 2013
    140
    Re: Steel Gantry CNC Milling Machine
    That looks beastly. Nice work. Kind of hard for me to get a sense of scale. What is the cutting envelope on it?
    Dec 2015
    23
    Thanks, table is 700mm x 700mm I might have a better photo to show scale
    Dec 2015
    23
    Attachment 308998
    Jun 2013
    1041
    That machine looks awesome so far. Great job. The only thing I don't like is the round linear rails in the drawing. They do not do the structure any justice. If you haven't already purchased them I'd seriously consider square rails instead. If you go with round rails they'll be the weakest link in the machine and not take advantage of the strength of the structure.
    Ben
    Dec 2015
    23
    Thanks Ben, I've already got the round rails from the wooden prototype for this one. However listening to what you're saying it might be well worth changing my idea. Do you think they would really make that much difference?
    Sam
    Jun 2013
    1041
    If your goal is just to cut wood then you will probably be ok. If you plan to cut aluminum or steel the difference would be night and day. Profile rails add many orders of magnitude more rigidity when mounted to a suitable structure. Your base looks rigid enough to support them properly. The profile rails and blocks should be 5-10 times more rigid.
    Ben
    Jan 2008
    1529
    After all that work you absolutely must use profile linear bearings. I've used new hiwin ones bought on aliexpress. Found them very good.
    There are different preload and precision grades available. For this sort of machine I would recommend medium preload and the better precision grade.
    Are you getting it stress relieved and ground?
    Dec 2015
    23
    My aim is to be able to cut anything and everything, within the limits of the machine. steel would definitely be on the list. With the amount of time I've put into it I definitely want to make it as good as I can, looks like I'm shopping for HIWIN then! ;-) 5-10 times more rigid would definitely be worth it! Thanks
    Dec 2015
    23
    I will have a look for HIWIN rails on aliexpress now, thanks for that! Does the pre load have anything to do with table weight?
    The aim is that it will be ground and scrapped. Considered stress relieving it but not sure where in France I could take it.
    Dec 2015
    23
    Attachment 309058Attachment 309060Click image for larger version.
    Just working on the feet for the stand at the moment, really wish I had posted on here at the beginning. Better late than never I guess!
    With round rails, you'll have a collection of very rigid components held together with sloppy linear rails - not good.
    You probably want 20-25mm rails with a medium preload on them.
    Aug 2004
    780
    Fabulous work.
    The best build I have ever seen, for steel.
    Agree on linear rails.
    Bigger is better.
    Go for 25 mm.
    Higher preload is better, especially for milling, and usually very low cost difference.
    Dec 2015
    23
    Thanks for the advice ger21 I'm planning on building a second machine with what I have at the moment and save up to get this just right. ;-)
    Dec 2015
    23
    Thank you hanermo!!! Your comment certainly put a smile on my face! ;-) 25mm is on the list!!
    Dec 2015
    23
    Got the plates welded on and all ligned up, took a while but I'm happy with how it turned out.
    Attachment 309090Attachment 309092
    Next on to the feet!
    Dec 2015
    23
    Attachment 309100Attachment 309102Attachment 309104
    Used the lathe to make sure all the feet ended up the same height, I know the floor certainly isnt!
    Dec 2015
    23
    Attachment 309106
    Attachment 309108
    I couldn't resist just putting everything together to see what it looks like!!! And I'm well happy!!!!
    Attachment 309110
    Attachment 309112
    Prototype and its successor!!
    The garage isn't always that messy (maybe sometimes!) Just needed to move some stuff to get the mill in its resting place!
    Attachment 309114
    May 2014
    97
    Nice build. Posting to subscribe.
    +1 on profile linear rails; it would be a crime to save a few bucks considering the amount of work you have put into that beautiful frame.
    Dec 2015
    23
    Thank you Eddard Stark! ;-)
    I was thinking the same thing, only have to buy them once and hope it will out last me!
Page 1 of 2 12
  1. New Build -- Moving Gantry Milling machine
    By 007CNC in forum Vertical Mill, Lathe Project Log
    Last Post: 07-09-2012, 10:31 AM
  2. A DIY CNC machine capable of milling aluminium and possibly steel
    By yezard in forum Uncategorised MetalWorking Machines
    Last Post: 06-14-2012, 10:18 AM
  3. 4'x8' Steel Table, Aluminum Gantry Machine
    By NeedAnotherTool in forum CNC Wood Router Project Log
    Last Post: 01-20-2012, 05:48 AM
  4. 1st Machine, Steel ,Overhead Gantry
    By bradodarb in forum CNC Wood Router Project Log
    Last Post: 10-18-2006, 08:05 AM
