586,508 active members*
3,089 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Attempting to Make a Mold in BobCAD V26
Results 1 to 11 of 11
    Feb 2016
    5
    Hello,
    I'm attempting to make a mold for a lure design I'm working on. Drew the top and side view out in 2d, I'm trying to make the side views into one solid so I can utilize the 3d milling feature in BobCAD. If anyone can assist in telling what I'm doing wrong, that would be greatly appreciated. I'm attempting to extrude each view and subtract where the extrudes intersect. Ideally that would make the 3-d model, right? I've attached the file I'm working on for reference.
    Jun 2008
    1838
    Re: Attempting to Make a Mold in BobCAD V26
    Quote Originally Posted by fishinmachinist View Post
    Hello,
    Please see attached file, hope it is what you are looking for
    What I did was take your 2D shape and used the "Surfaces > Revolve 360 degrees" and created what I believe is your lure, then I just used your retcangle to extrude a solid for the stock and then used the "Solids > Subtract" to cut the shape of the lure out of the stock solid
    Done in V26 Build 1335 so I hope you have that build otherwise you won`t be able to open the file
    Attachment 309128
    About 6-7 minutes work that`s all, if it`s OK for you that is, if not it`ll need some more effort
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Feb 2016
    5
    Thanks, but that is not quite what I was thinking. That works for the rear section as that is just a cone. I've got one as a go-by that I have taken a couple pictures of. What I do not know how to do is to make the constantly changing radius on the front and sides of the main body.
    Edit: You can ignore the eyes.
    Jun 2008
    1838
    Ah, OK, I see now what you need, there was only geometry for the shape I did.
    You need to draw the shape you want for the backbone and the belly of the fish in the top plane and join them to the existing geometry at each end in a different plane using another UCS ( Side will probably do it) and then skin the geometry to get the desired shape.
    Sorry I don`t have time to do any more right now, it`s 1.15am her and I am off to my bed
    Feb 2016
    5
    That's exactly it!
    Unfortunately, I'm too unfamiliar with BobCAD to do that, so the back and belly are profiled out using the top view. The side is done on the front view. The tail section can be done with a simple revolve, as it is just a cone (I believe). What function would I need to use to make the skin?There's so much I need to learn here, I'm used to just using BobCAD for some bolt patterns and 2D drawings.
    I'll keep messing with it a while here as it's not quite as let in the states. Thanks Rob,
    Chandler
    Feb 2016
    5
    ok, so this is what I've got so far. I'm trying to make the bottom of the mold less like a V and more like a radius.
    Jun 2008
    1838
    OK, have a look at the attached file, I have done a rough segmented example for you to show what you need to do.
    Attachment 309932
    Basically the easiest way is to break your lines up into sections, put points at the ends and then use the "Arc > Three Entity" facility to create arcs between the points, moving the lines and/or re-shaping them will allow you to use the "Surfaces > 3 Edge or 4 Edge" to surface each section, the more arcs you put in the better the shape you can create
    There are of course other ways to do what you want but IMHO this way is fairly easy
    Hope this helps you a little
    Attachment 309930
    Regards
    Rob
    Feb 2016
    5
    Thanks Rob! So, from what I understand, I would use the break entity utility to segment the three lines, then use the arc three entities to create more arcs. To make the surfaces, use the 3 or 4 entity surface? I would also like to be able to do that with the front as well. I also need to straighten out the rear, it tapers out where it should be straight instead. I'll keep at it! Thanks for the help!
    Jun 2008
    1838
    Yep, that sounds about right, sorry I can`t do more right now, just on a tea break from laying carpets upstairs
    Regards
    Rob
    Dec 2008
    4548
    Cross section. Arc to cut hole to match tailpiece.
    Attached Files Attached Files
    Mar 2012
    1570
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
  1. Make mold for larger part
    By hive8 in forum Benchtop Machines
    Last Post: 04-19-2013, 10:56 AM
  2. Want make a balustrate mold from wood.
    By GASANT in forum WoodWorking Topics
    Last Post: 01-31-2013, 05:00 PM
  3. Which material or substance should I use to mold and make Panpipe?
    By blue.traveller in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 05-26-2012, 04:53 PM
  4. How to make a mold out of polyethylene Plastic?
    By BigChad in forum Moldmaking
    Last Post: 07-09-2011, 06:31 AM
  5. How to make a mold of this?
    By rushy in forum Moldmaking
    Last Post: 06-23-2008, 03:57 AM
