awesome stuff hoss, i cant thank you enough man... for some reason. i kept having to get to the screen set through the view button... so i put the files in the corresponding files in mach 3 folder and the screenset shows up automatically when i open now... i test on my laptop first then install on the mill rig so i dont screw anything up where it counts... LOL/// i tested with just the tool setter by touching the plate as it was finding edges and centers.... AWESOMMEEEEEEEEEEEEEEEEE HOSS.... ill be ordering a probe in a few days and a seperate tool setter cuz i dont like the idea of disassembing the touch probe to set tools
question......do the touch probe and tool setter have to be the same type...by that i mean do they both have to be of the type that closes to complete circuit...or can one be Normally open and the other normally closed
I.is there a way to slow it down when it returns to the zero point after finding the edge... just curious if not..im happy as hell annyway....
so your screenset is working with no effort on my part.... your the the man hoss...
then i got to work setting up the pendant... i received it yesterday from russia...the shuttleru... super awesome little piece of work and worth the money i think...its built like a fricken tank... the seller was perfect in every way ...fast to respond to messages and i recieved it ready to go fully programmed with sd card ... i couldnt get a handle on how to set yp the screens so he was nice enough to set it up like his and the onlly function that doesnt work is the elasped time dro... i cant get it to show the elapsed time..once i fuigure out how to set it up myself ill take a stab at making my own screen sets for it...but as it stands it does absolutely everything i need it to do with about 10 functions left over for whatever i may need...
man its much better setting up parts with this thing...
i had the vfd plugin working on my laptop for the huanyangvfd... but had a hjeck of a time getting the right driver on the mill computer...but finally i got it... once i found the driver... it was easy from there...vhangred the settings in the vfd ... crossed the 2 wires going to the vfd and voila there t was... fnstant full control of the motor and vfd through mach3 ... with correct displays on the dros of mach3 and pendant.. the motor will go as low as 50rpm if i want it to..
im set up at 1 to 2 on the belt drive ...so im not sure what rpm i should end up with for tapping...well see i guess..
im out of excuses and its time to machine the motor mounts for the belt conversion.. starting this week... i hope it goes well
the camera plugin works great on my laptop...but on the mill computer it would freeze up and not recognize the camera...and it was missing the crosshair for some reason... not sure... so i ended up using the camera plugin from k dietz which works great..
thanks again guys
