586,103 active members*
3,311 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > cincinnati sabre 4th axis problem
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Apr 2011
    95
    Re: cincinnati sabre 4th axis problem
    Thanks Mike dont sell yourself short your 2 cents worth is worth big $ to us turns out the home switch will show in the io screen on initial start but to see the ot switch the on button needs to be pushed the second time power on but we were not happy about sticking hands under the bed with power on
  2. #22
    Apr 2011
    95
    Ok almost there with this thing now im getting this message Click image for larger version.
ID:	314578 any help would be appreciated ive nearly had enough of this thing
  3. #23
    Sep 2010
    1765
    you get it?
  4. #24
    Apr 2011
    95
    Not yet the I got the servo display up reads zero in the rpm so is there some sort of speed sensor some where
  5. #25
    Sep 2010
    1765
    yes, it is an encvoder output from my VFS5 drive to a2100....
    sabre machine??? looking... see arrow, bprob same. cable 2615...., from vfs5 C1 to A2100 PCA1 axis port. this is the encoder output sig from spindle to cnc so it can tell where it is and what speed is running....
  6. #26
    Apr 2011
    95
    It knows where it is it positions it self for a tool change
  7. #27
    Sep 2010
    1765
    oops, my bad. sorry. don't know where my mind was with my last reply (actually I probably don't want to blame it on the beer)... try this instead...
    my prints on sabre show on page 24 of 40 the upto speed output relay CR13. this relay gets turned on by wire 2402 from page 26 line 25...
    This is output2 from top of VFS5 C8 connector. seldom is the WIRE bad. check that CR13 is turning on an off. this goes back to a2100 as at speed signal.
    it goes into a211 on page 11 of 40, cr13 as wire 111`2 from relay thru various plugs (where the sig can get lost) and becomes io screen input 100:00/24
    The setpoint rpm VEXT is compared to the actual speed VAVG andif within 10rpm, upto speed turns on; turns back off when 5 rpm off. cnc has timer like 5-8 sec: if not seen when it should be seen in that time, it gives the error you see.
    use your a2100 io screen to verify that input comes on/off.
  8. #28
    Apr 2011
    95
    Ok CR13 is on and stays on all the time here is the io screen pics 1 before start spindle 2 spindle running 3 stopped error message Ive have watched the servo display and it shows the spindle speed as zero also having a bit of a look around the spindle motor found cable 1205 or PRS5 just sitting there not connected but I can not find where it goes or if its needed Attachment 316156 Attachment 316160Attachment 316158
  9. #29
    Sep 2010
    1765
    your io screen look correct with upto speed on except when accel or decelerating... so no clue why cnc would be reporting not to speed? wierd...
    related to 1205 loose? no clue... maybe you need to talk to fives tech guys...
    one of the 1205 wires ends up as 1224 to front of vfs5 C3 as HOME switch input.... not sure why this would effect anything on upto speed. pix attached is sheet 12 of my sabre diagrams...
  10. #30
    Apr 2011
    95
    Hi Mike you mentioned in a previous post check that CR13 is turning on an off. this stays on does not go off is this still ok
  11. #31
    Sep 2010
    1765
    Quote Originally Posted by juniormachinist View Post
    if stuck on or stuck off, no, no good....
    but you sent a screen shot (32) showing it off!?!?
  12. #32
    Apr 2011
    95
    Hi Mike just got in to work and checked again the light on relay CR13 stays on and does not go out when we run the spindle or get the error message is this right or wrong
  13. #33
    Sep 2010
    1765
    wrong. trouble shoot where the sig is lost.
Page 2 of 2 12
  1. Replies: 6
    Last Post: 01-15-2019, 04:32 AM
  2. Replies: 2
    Last Post: 08-17-2015, 08:51 AM
  3. CINCINNATI SABRE 750 X.Y.Z AXIS FAILURE
    By hawk1 in forum Cincinnati CNC
    Last Post: 11-13-2010, 02:09 AM
  4. Sabre 750 Fanuc 0-M problem with 4th axis control
    By Lemi in forum Cincinnati CNC
    Last Post: 02-10-2010, 08:40 PM
  5. Z-axis problem- Cincinnati Sabre 750
    By JameyLH in forum DNC Problems and Solutions
    Last Post: 08-21-2008, 05:16 AM
