586,072 active members*
4,683 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > What is proper lube for small rotary table?
    Feb 2016
    4
    Question What is proper lube for small rotary table?
    I have a Gavin (India) 4" rotary table which I have disassembled. It has been factory lube'd with some sort of heavy, sticky oil on the shafts and some rather nasty looking/smelling grease on the worm gear on the table. Would like to clean this all up and put some better stuff on.
    Is that 'sticky' oil a Good Thing' - I'd like to just clean it all with mineral spirits and put Lithium White grease on the gears and use synthetic gear oil to lube the rest of it.
    Ideas?
    =A.
    Jun 2010
    4256
    Re: What is proper lube for small rotary table?
    The 'heavy sticky oil' may be shipping grease: keeps the parts from rusting in transit.
    I can't imagine you could do any harm at all by stripping all the shipping grease out completely, then adding a small qualtity of suitable grease or oil. Some waterproof wheel bearing grease might be fine.
    I once bought a very simple new-in-box Japanese sewing machine for my wife. It would not work when we got it home. The demo unit had been fine. I found shipping grease on the main vertical shaft (the one that goes up and down with the needle on the end). I cleaned all that off and then lubricated the shaft with light machine oil. Thereafter the shaft FLOATED in the cast iron bearing. Beautiful.
    Cheers
  1. Vacuum table help. Custom table for small acrylic parts.
    By czwalga in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-09-2014, 03:06 PM
  2. Adding a rotary encoder to a large Rotary Table
    By small.planes in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2012, 07:27 PM
  3. Small rotary screw air compressor
    By JKuhn in forum MetalWork Discussion
    Last Post: 02-02-2012, 09:14 PM
  4. Proper rotary axis usage?
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 07-18-2011, 03:25 PM
  5. Proper mount for a small router
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 12-06-2010, 05:42 PM
