Is the drive in working order now, and you want to re-interface it with a new control?
If so I would look at that route first, The only thing is it has 3 phase input, which may not take kindly to RPC supply.
The VFD approach, means you can use 1 phase in, and you should be able to get a VFD with what the DC drive/motor will fetch.
This may save alot of time, over trying to modify the 1ph SCR drives.
Al.
Albert E.
