586,341 active members*
3,121 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Mitsubishi EDM, Blasting water from lower head?
    Feb 2016
    Hi everyone, just like the title says I'm have a problem with my FA10S wire EDM.
    Whenever I start the machine or try to thread the wire, I get blasted by a jet of water from the bottom head.
    This machine has been sitting for about a year and I'm trying to get it up and running again. I have taken everything apart and cleaned it, as well as replaced all the O-rings I could find.
    Any ideas would be appreciated.
    Feb 2016
    Re: Mitsubishi EDM, Blasting water from lower head?
    I'm starting to wonder if I need to look at all the solenoids? do you guys think one of them could be clogged?
    Jul 2016
    4
    Quote Originally Posted by RockRiver View Post
    I did have this problem one time. I had taken apart the machine to clean it and my co-worker decided to put it back together and reversed the hoses which caused the water to shoot up like old faithful from the lower flush cup. Easy fix just switched them. If that doesn't work you are probably looking at checking solenoids E, G, and C ; might as well clean valves A & B(good idea) ; also examine the F valve. The F is the constant throttle valve. Valve K and G play a part in this too I believe. In front of your manual you should find a dielectric Fluid Circuit Diagram. In mine it was in 1-48. Hope that helps a little.
    Tvalen1432
  1. Lower head alignment
    By RforEDM in forum EDM Discussion General Topics
    Last Post: 02-16-2015, 05:48 AM
  2. Dry Ice Blasting Services
    By DoneRiteSS in forum For Sale Only
    Last Post: 08-01-2014, 02:15 PM
  3. wire edm lower head trouble
    By cellis in forum EDM Discussion General Topics
    Last Post: 07-13-2013, 09:56 PM
  4. WANTED: Laser cutter air assist head & Water chiller (for cheap)
    By mowcius in forum Want To Buy...Need help!
    Last Post: 07-20-2012, 12:16 AM
  5. power head to raise and lower non cnc
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 01-05-2008, 07:32 AM
