586,123 active members*
3,359 visitors online*
    Feb 2016
    Wanting to build a 5x10 table.
    Wanting to build a 5x10 Gantry Kit table, where do i start? Where can I get a set of plans and are the all generic or specific to the gantry brand? I will be using it mostly for HVAC parts, so it will be a down draft. I saw some heavy duty tables along the lines of having 4 inch tube for legs.
    Feb 2006
    1260
    Re: Wanting to build a 5x10 table.
    If you are going to use someones "gantry kit" or buy most of your "hard parts" in a kit form..... they most likely will have table plans to go along with gantry..... I expect you will have to buy the kit to see their table plans though
    If HVAC or other very thin material is all you are going to cut I'd probably go with some sort of 80-20 aluminum frame
    If it works.....Don't fix it!
    Mar 2004
    93
    Just a note...Designed correct 80/20 can be a extremely strong table.. It will support a heck of a lot more then sheet-metal.. In fact mine will support as thick as my 120 amp cutter could cut through reasonably well. Most of the problem is cost of doing it correct compared to using steel..
    Jun 2014
    30
    For making the table yourself,it is a little complicated.You can calculate your budget,if it is much money,we suggest you to choose Chinese machine.The price is more economiclly.
    Here I attach the machine pictures for your reference.
    Any question,please feel free to contact me. [email protected] or [email protected] .
  1. 4x8 or 5x10 - Table Build Options
    By Bob La Londe in forum Avid CNC
    Last Post: 10-26-2015, 08:23 PM
  2. DirtBound Offroads New 5x10 Plasma Table Build
    By DirtBound in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-05-2014, 11:34 PM
  3. PrecisionPlasma/CandCNC 5X10 table build
    By Teknition in forum Waterjet General Topics
    Last Post: 04-01-2013, 08:34 PM
  4. Amateur 5x10 waterjet table build
    By chimpera in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 10-25-2012, 03:39 AM
