586,094 active members*
3,955 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > spindle recommendation for cutting mild steel
    Apr 2006
    1016
    Hello
    I like to hear who had much success, cutting mild steel using a chinnse spindle with there cnc.
    I would like to know what cutting speed what tooling was used and size make of spindle etc.. coolent or oil etc.
    I know mill would be better suited (lower spindle cutting rpm and more ridged setup)
    for my need but i dont have that option currently. Currently using a router, I need to upgrade
    To something more powerful like 3kw spindle for my next build, seeking advice from fellow cnczone users.
    Jun 2013
    443
    Re: spindle recommendation for cutting mild steel
    Hi. How did you get on? I see no replies and am wondering what your results were as I am thinking I will try the same.
    Feb 2016
    381
    I have a 2.2kw water cooled 6-24k rpm on my router and a tiny 500w 200-5000rpm on mini mill, the mini mill is far better cutting mild steel lower RPM more torque and rigid with aluminium no difference but with mild steel they are chalk and cheese.
    Apr 2004
    5737
    As Louis notes, the requirements for a spindle that cuts steel are quite different from one that cuts wood and aluminum. You'd be better off constructing something yourself from scratch, using a regular induction motor, a pulley cluster, and a bearing-mounted shaft with a collet chuck, than attempting to use a high-speed spindle, which has very little torque when slowed down to the steel-cutting range, no matter how powerful it may be.
    Andrew Werby
    Website
  1. Low speed mild steel spindle needed
    By gtrdude in forum Uncategorised MetalWorking Machines
    Last Post: 01-28-2009, 01:20 AM
  2. What kind of cutting speeds are u running on mild steel?
    By Legion99999 in forum Syil Products
    Last Post: 06-20-2008, 11:34 AM
  3. VF-2 Cutting 1/4" Mild Steel plate
    By akedward in forum Haas Mills
    Last Post: 11-25-2007, 01:05 AM
  4. Cutting 1" Mild Steel
    By 3DSteve in forum Waterjet General Topics
    Last Post: 06-14-2007, 10:58 AM
