586,069 active members*
3,946 visitors online*
    Apr 2012
    Sheetcam Plsma. Post prosser requires Diameter.
    I am setting up an installed a Command CNC Linux system in my existing Mach 3 DHT II system. I run plsma only. Sheetcam is downloaded onto the CandCNC computer I purchased and is set up for Linux. Most sheetcam tools the same as I have used in my older Sheetcam Mach 3 system but when I went to run a simple oval cut through this new Linux Sheetcam process I got post Processor failed. "Define a diameter". Iam not drilling or running a router. How do I get rid of this post processor diameter issue?
    Sep 2008
    18
    Re: Sheetcam Plsma. Post prosser requires Diameter.
    You should enter the kerf width as the diameter. In other words, the plasma flame itself has a diameter, and you can figure out it's size by measuring the width of a straight cut.
  1. Can anyone help with sheetcam post processor?
    By twooten in forum SheetCam
    Last Post: 03-30-2015, 06:48 PM
  2. Can anyone help with sheetcam post processor?
    By twooten in forum Waterjet General Topics
    Last Post: 01-25-2008, 09:02 PM
  3. sheetcam 5.0.1 post processor for dynacnc
    By lowelife in forum Post Processor Files
    Last Post: 10-07-2007, 09:14 PM
  4. Hurco BMC20 Post Prosser help
    By moorport in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2007, 05:19 PM
