586,077 active members*
3,591 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V24 splice planner boundary removes tool path
    Feb 2011
    38
    I have some parts to surface in V24 that contain a step wall. When I try to add a boundary at the step to keep the tool away (.500 ball nose) the tool path vanishes. If I remove the boundary, I can then re-generate the tool path.... what am I doing wrong? I tried the same part in a copy of V26 I have and get the same issue.
    Thank you!
    Erik
    Re: V24 splice planner boundary removes tool path
    I think that the function of the boundary you are setting excludes rather than limits the area where your tool path resides and this is why the path disappears/reappears as you describe,
    - Nick
    Mar 2012
    1570
    Erikh 206 ,
    When it comes to planar and using a boundary, make sure there is room for the tool. The tool center is driven on the boundary. If you are cutting a more vertical wall and you have a boundary right the edge, there will not be enough room for the tool to fit, which is why the toolpath goes away in that spot.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    1570
    This video should help.
    https://youtu.be/mqOpwwEOWZM
    Al DePoalo
    Feb 2011
    38
    Thank you both for your replies. Turns out I was trying to restrain the step wall only. I failed to notice you must have a box set up and not just one line for a boundary. Once I created four sides to the boundary, all was well.
    Erik
  1. V27 Final pass in nesting removes tabs
    By KSky in forum BobCad-Cam
    Last Post: 12-01-2014, 03:53 PM
  2. Replies: 15
    Last Post: 01-09-2014, 01:43 AM
  3. tool size concept- tool path generated vs gcode
    By kjl-pdx in forum Mach Mill
    Last Post: 03-12-2013, 07:25 AM
  4. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  5. Replies: 4
    Last Post: 07-04-2011, 02:55 AM
