586,051 active members*
3,627 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Water pump for water cooled spindle
Results 1 to 2 of 2
    Sep 2014
    4
    Hi
    Im trying to figure out a good water pump to use for my water cooled spindle. The pump I have now is a submersible 120gph pump and it dosnt have the lift I need. The fittings on my spindle are for 1/4 inch i.d. tubing and the lift I need is 5 to 6 feet. If anyone has any suggestions for a pump that would have the power I would need it would be great.
    Jun 2015
    73
    Re: Water pump for water cooled spindle
    This is what I use. Seems to work fine. The flow is low going through the spindle, but I think that's due to the small passage ways in the spindle...NOT the pump. The pump is not cheap, but quality. Hope that helps.
    Aqueon® Quiet Flow Submersible Aquarium Power Pump | Water Pumps & Powerheads | PetSmart
    Justin
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. VFD/Water Cooled Spindle Help
    By Jerseydog in forum Spindles / VFD
    Last Post: 05-02-2015, 02:54 PM
  3. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  4. Water Cooled Spindle
    By sylvan in forum CNC Tooling
    Last Post: 09-03-2011, 12:20 AM
  5. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
