587,030 active members*
3,473 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > how to connect vacuum pomp and vacuum switch
Page 1 of 2 12
Results 1 to 20 of 21
    May 2014
    37
    Hi folks,
    I have a pomp and a switch, I am starting to making my vacuum cnc table.
    Do you know how to connect that switch to the pomp ?
    What cables will I need for that ?
    I have that switch so it will start / stop the pomp when necessary so the pomp will not need to work all machining time. I engrave acrylic sheets. (No cut through)
    Table is 400x400mm I plan to divide it into 4 separate vacuum sections.
    Many thanks for help.
    Tim
    Mar 2007
    2083
    Re: how to connect vacuum pomp and vacuum switch
    I'd expect the wiring will be like that for a compressor and will be some thing like this -
    Attachment 310176
    john
    Attached Thumbnails Attached Thumbnails compressor  or vacuum pump wiring.jpg
    May 2014
    37
    Quote Originally Posted by john-100 View Post
    john
    gosh i dont understand much out of that ...I was thinking that will be like plug in and start working...
    Mar 2007
    2083
    Hi tommy
    do you know if your vacuum switch can handle the motors start up current ?
    if it can this is the minimum you need -
    Attachment 310252
    I prefer to have a no-volt starter on any machine
    so if the mains supply to your work shop is lost for any reason ,
    it can't restart when the supply comes back on
    john
    May 2014
    37
    thanks for that diagram, looks way easier
    May 2014
    37
    Hi tommy
    john
    here is all detail for that vacuum switch
    http://www.portalnaukowy.edu.pl/alle...ogowe/vs-d.pdf
    Mar 2007
    2083
    Hi tommy
    WARNING - that pressure switch can't switch the mains supply to the vacuum pump !!!
    I need the part number of the switch to see if it has a NPN transistor output or a PNP transistor output
    it will need additional parts to be able to switch the mains supply to the pump on and off
    John
    May 2014
    37
    my one is PNP - it says on the sticker.
    you sure I will need extra device ?
    like this one ?
    STYCZNIK MOCY DILM7-10(24VDC) 3P 7A 24V DC 276565 EATON MOELLER
    Mar 2007
    2083
    Hi tommy
    taken from the manual -
    Attachment 310264
    Attachment 310266
    the electronic pressure switch needs a 10.8 to 30 V DC supply and has two outputs that can only control 180 mA
    at the very least you will need to power the switch from a 24V DC supply and use a relay with a 24V DC coil to switch the pump motor on and off
    for example this relay can switch a 10A load ( at switch on 30A for 20ms)
Name:	24V DC relay.pdf
    John
    Mar 2007
    2083
    Hi tommy
    a wiring diagram to use your pressure switch
Name:	vacuum pump with 24V electronic pressure switch.jpg
    the output used needs to be programmed as normally closed
    John
    PS
    I had assumed in posts 2 and 4 you had the old electro mechanical type of pressure switch
    Mar 2007
    2083
    Hi tommy
    last night I missed your link to the Eaton Moeller contactor - it will be ideal to control the pump
    now I have read these data sheets -
    DILM7-10(24VDC) | xStart DILM 3 Pole Contactor, 7 A, 24 V dc Coil | Eaton
    http://docs-europe.electrocomponents...6b80ff30ba.pdf
    the contactors 24V DC 3W coil will take 125 mA which is about 70% of the current the pressure switch can control
    Attachment 310324
    use a 24V DC supply that can supply a minimum of 250mA (6W)
    John
    May 2014
    37
    many thanks for help mr jonh 100 .
    I have all knowledge to make it work.
    Will post pics when finished !
    how to set N/O in my Moeller device?
    May 2014
    37
    John
    will that be OK ?
    Zasilacz impulsowy 24 VDC, 1A ?
    Mar 2007
    2083
    Hi tommy
    yes you can use the 24V 1A supply
    the 24V contactor coil will take 125 mA , the electronic pressure switch 55mA
    the total current taken from the power supply will be 180mA ( 0.180 A)
    to answer post 12 the Eaton Moeller contactor contacts L1 & T1 , L2 & T2 are normally open
    the only thing that can be done is to program the pressure switch out put as normally closed
    Attachment 310510
    so the contactor will be closed when the air pressure is high
    and opens when the pressure is at your preset negative pressure required
    John
    May 2014
    37
    many thanks for more help
    more questions
    1. is that ''normal pressure that should be displayed when I close the cable coming out from the pomp - 10mm cable - with my finger ?
    Here is all the connectors and cables I buy today. almost 50 $ .
    Want to make 4 separate areas of vacuum.
    Mar 2007
    2083
    Hi tommy
    is the vacuum gauge showing the - 2 psi pressure with the pump running and the inlet blocked ?
    I would expected you to have some thing closer to - 10 psi or -12psi
    John
    May 2014
    37
    Hi tommy
    John
    thay say its becouse of very small area of the cable that is active sucking section...if I multiply that by 30 it would hold many kilos....at least this is what I was told...
    Jun 2010
    4256
    Frankly, why bother?
    I switch the vacuum pump on to hold the job down and switch it off when I am finished. No harm done, the pump just sits there trying hard. It is MEANT FOR THAT.
    On the other hand, if your vacuum system is only getting down to -2 psi, then either you have a really crappy vacuum pump, or your vacuum system has massive leaks! I suspect the leaks, so first fix them.
    Yes, if you have massive leaks in the vacuum table and a very small pipe to the pump, then the pump will not be able to get a decent vacuum at the table. FIX the leaks!
    Cheers
    Roger
    Mar 2007
    2083
    Hi tommy
    what kind of vacuum pump do you have
    if it has sliding carbon vanes as used in the Hydrovane rotary compressors you need the correct level of oil to provide the air seal
    John
    Jun 2010
    4256
    Good point. Mine is a sliding vane one with oil. The diaphragm pumps can also run continuously against a hard vacuum. I am not sure about the other sorts though.
    Tommy: best check first.
    Cheers
    Roger
Page 1 of 2 12
  1. Vacuum pump size for vacuum hold down jig?
    By dawgwalker in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-21-2014, 03:07 AM
  2. Vacuum Fixture with Festo Vacuum Generators ?
    By yaji63 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-09-2013, 08:52 AM
  3. Replies: 1
    Last Post: 05-03-2013, 12:42 AM
  4. vacuum switch ?
    By Claytonc in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-15-2012, 12:24 PM
  5. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
