586,115 active members*
3,351 visitors online*
    Feb 2016
    im stuck and dont know what to try
    I have tried many different things with the stepper motor setup on a plasma table i am building, im using nema 23 motors at 280oztorque, when manually jogging the motors they dont move fast at all, im talkig about moving a foot and it taking 3 to 5 minutes, my table is small its only a 4x4 table using linear slides and ballscrews
    im using ballscrews with a 5mm pitch i am using stepper motors with 6 wires but only using 4 wires red, blue, black, and green, right now i have the board that everyone hates which is the tb6560 which i will be replacing once i can make sure i can get some speeds out of the motors and not waste more money on something that wont work.
    also what kinda heat should be coming off the stepper motors because they can get extremely hot.
    which decay setting should i use on dip switches, along with current and even the steps, the wiring documents given to me are not very good
    Jun 2008
    562
    Re: im stuck and dont know what to try
    You might find some useful information here: 4 Axis TB6560 CNC Stepper Motor Driver Board Controller - RepRapWiki
    Good luck
    Mike
    Mar 2012
    231
    Look at the dip switches and also you motor tuning in Mach3....
    CR
    Jul 2005
    2415
    Shift-Jog key is fast jog. Motor tuning steps per unit and velocity in IPM determine max speeds
    Jun 2004
    6618
    Steppers can get hot and sill be okay.
    Lee
  1. I dont know what I am doing
    By shortnut in forum DIY CNC Router Table Machines
    Last Post: 02-18-2015, 11:40 AM
  2. Now you see me now you dont!
    By mountaindew in forum SprutCAM
    Last Post: 05-28-2014, 03:30 PM
  3. I dont know where to ask this so i will ask it here..
    By randyrw in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2011, 03:46 PM
  4. i dont know wat i'm doing!
    By flow101 in forum European Club House
    Last Post: 06-26-2010, 08:44 AM
  5. I need some help. Dont know what to do.
    By slammedxonair in forum DIY CNC Router Table Machines
    Last Post: 01-13-2009, 10:52 PM
