I already started a thread but now I see that it is in the wrong section (http://www.cnczone.com/forums/showthread.php?t=30066), my appologies.
So now in the right place
I have recently started designing my first CNC machine
The dimensions the cutter can reach are about 90cm x 70cm x 10cm
As for the linear bearing I use the following parts:
20mm steel rod for the x and y shafts. for the x axis I will support this rod in the middle to prevent bending.
the bearing itself consists out of 2 bended (120 degree) plates (4mm thick) welded on a plate for fixture. on these plates i connect some bearings (6 on every side)
for the Y axis i'm not sure weather I'll use a sliding bearing or the same bearing as described above.
The z-bearing is a sliding bearing on a 15mm shaft.
I already bought 3 1.7Nm steppers and for the drivercard i'm building the PICstep at the moment. I have some trouble finding a shop that sells the IC DIGIKEY LMD18245T-ND for a reasonable price over here in Holland. I can order them at digikey, but i don't know if i have to pay taxes and importing costs etc. Does anybody know where to find them in europe?
every comment on the design is welcome since i'm not sure weather the design is stiff enough.
Many thanks
Hendrik
[edit] added a picture of the linear bearing i want to make
