Posting for a lathe with live tooling. Everything works great in X6. Tool paths look good. Everything for the normal lathe operations code looks good. NC code for face milling operation gives x and c values. The c values aren't degrees. They're larger numbers, like what a y value should be. Lathe obviously rejects this as bad code. Just a small guy getting started. Don't know much about much. No one started out knowing everything. Any help would be greatly appreciated. Thanks
