587,006 active members*
3,100 visitors online*
    Feb 2016
    38
    Tool Measure nk105 Weihong
    I have a router with a weihong NK105 controller. Has anyone an idea how to measure the tool after tool change? I can set offset for different tools, but when I change the tool how should I be sure that it is inserted with the same offset as I measured before starting the job? When the tool change is requested, the machine goes into pause mode and I can only continue or stop. All other functions on the DSP are not recognized in the pause state.
    Dec 2014
    19
    Re: Tool Measure nk105 Weihong
    The solution in industry is usually independent of the controller - set and save your tool offsets, then use a tool holding system that displays an acceptable degree of repeatability.
    Tormach has their TTS system, some people use endmill holders in collets (bumping the bottom of the end mill holder against the face of the collet), etc. Your solution is dependent on your spindle setup.
    Jul 2019
    I am having the same issue with my NK105 G3 controller. " When the tool change is requested, the machine goes into pause mode and I can only continue or stop. All other functions on the DSP are not recognized in the pause state.
    Did you figure it out? I'd love to know i currently can't change tools. have tried everything under the sun!
    Feb 2016
    38
    Sorry, I have no news on that topic. A workaround is to make multiple cnc files.
  1. Post processor for Weihong NK105
    By Chop3d in forum Chinese Machines
    Last Post: 11-19-2014, 06:47 PM
  2. Question on the menu panel WEIHONG NK105 g2
    By andu in forum Machinery Manuals / Brochures
    Last Post: 04-19-2013, 01:38 PM
  3. tool change and measure tool lenght, macro?
    By Charon in forum Mach Wizards, Macros, & Addons
    Last Post: 03-20-2012, 06:56 PM
  4. Hit Tool Offset Measure by accident
    By BBQ70 in forum Haas Mills
    Last Post: 12-02-2010, 03:41 AM
  5. Offset, measure the first tool and second tool
    By domax in forum Daewoo/Doosan
    Last Post: 12-30-2009, 05:20 AM
