586,103 active members*
3,902 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Mill/Turn Y axis Instead of C
    Hello,
    Can you help me with the issue from title, i cannot find any settings for it...
    Thanks !
    Jul 2013
    31
    Re: Mill/Turn Y axis Instead of C
    Good day FlorinMBV
    Create your features as normal select tooling etc and run the simulation.
    Go back into the feature properties on your Toolbox and tick the "Cut Feature Using Y Axis Coordinate" Tick Box
    hope that helps.
    Many thanks j206!!!
  1. 2 Axis mill/turn lathe setup
    By eldzis in forum CamWorks
    Last Post: 05-04-2015, 03:07 PM
  2. cutter rad. compensation on turn-mill with y-axis
    By maximusek in forum Uncategorised MetalWorking Machines
    Last Post: 06-23-2011, 03:54 PM
  3. OneCNC mill/turn with C+Y+B axis module
    By Dan B in forum OneCNC
    Last Post: 02-19-2010, 08:00 PM
  4. RFQ - Program Emco 7 Axis Mill/Turn
    By C5Frenzy in forum Employment Opportunity
    Last Post: 09-19-2009, 04:48 PM
  5. Haas 4th axis live turn and mill.
    By Sam Mcquern in forum GibbsCAM
    Last Post: 04-23-2009, 02:32 PM
