just wondering where the best place to buy stepper/ servo wiring? Thanks
I am also wondering where to buy 6 wire for stepper motors. How much diameter of wire need to bee for 6 wire 3,5A 50V.
I thought that most stepper motor DRIVERS are 4 wire ?? Thus you only need 4 conducter to wire the motors ?? Did I miss something ??
Bill
Well, at any given time you can find wire on Ebay. Takes a bit of searching sometimes.
Home depot has multi-wire with shield, I've gotten some there too.
Also I've gone to one or another of the local electrical companies here and asked. They usually had what I needed. Sometimes I was required to pay...sometimes not.
Can I use this wire.
yes that wire should do just fine I would think.
That wire (shown) is 22 AWG I STRONGLY question that it can stand up
to the 3.5 Amps you mentioned before.
Look here
( http://www.powerstream.com/Wire_Size.htm) for a chart showing
Wire Gauge vs. Current Capicity. look at the 'power transmission'
Collum because you ARE transmitting power to those motors.
Mike_L
When I was younger I thought I knew EVERYTHING,
NOW, the older I get the more I find out I don’t know!
Action electronics has shielded wire in 4, 6, or whatever you want conductors. You should go for the shielded to keep the noise down in your system. I bought 6 wire. I use it for encoders, limits, and other connections as well.
Best,
BW
So in chart I need 16 AWG 3,7A.
BobWarfield: I find web page Action electronics but I not find shielded 6 wire.
Where to buy shielded 6 wire maybe in Europa.
That's funny as the picture you posted above is from their catalog.
BW
http://www.action-electronics.com/wirecable.htm
Action electronics have 6 Conductor Shielded 22awg, but I need 16awg.
Stepper cabel are they data cabel or power cabel.
On pic does it shielded cabel see arrow.
