586,075 active members*
4,291 visitors online*
    Apr 2015
    Plasma cutting Titanium
    I have a torchmate x with water table set up and powermax 105 for the power supply. Wonder what it would take to cut titanium with the set up that i have?
    Jan 2013
    58
    Re: Plasma cutting Titanium
    I have never tried cutting Titanium with plasma but from my experience of welding it you HAVE to prevent it from coming into contact with the atmosphere when at an elevated temperature. If it discolours any more then a pale straw colour then it is scrap as you will have embrittlement of the material.
    When welding it I either used a trailing argon shield or sometimes a sealed cabinet filled with argon and had to keep the argon flowing until the material had cooled down sufficiently.
    If you can cut under water then you may stand a chance as the water would protect the material from the atmosphere.
    However, I would think that you would need to use nitrogen and that may cause problems with contaminating the cut edge.
  1. Water jet cutting titanium
    By TitaniumProcess in forum Videos
    Last Post: 07-01-2015, 04:21 PM
  2. Replies: 0
    Last Post: 12-11-2014, 06:50 PM
  3. Titanium w/ plasma
    By plain ol Bill in forum Hypertherm Plasma
    Last Post: 11-16-2010, 01:51 PM
  4. X4 speedmaster cutting Titanium
    By syil canada in forum Syil Products
    Last Post: 09-30-2009, 04:05 AM
  5. Titanium cutting? What to use!
    By Tazzer in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2003, 01:56 AM
