Hi guys, got a question I cant seem to rationalize in my head. If I'm chamfering an edge and the edge runs directly into the wall, I obviously cant get in there with a chamfer mill and would need to lead out before colliding with the wall.
Is there an automatic way Fusion 360 will run the chamfer without having to manually model the lead out in the 3D model?
The highlight corner is what you get just adding a fillet between something that can be cut from two sides.
I could certainly model the path with the chamfer leading out before the corner but that gets to be tedious when you have a larger part with several tabs on a wall to chamfer that are not on an edge orthogonal to that surface or in the case of a 3D chamfer path.
