586,103 active members*
3,737 visitors online*
IndustryArena Forum > Community Club House > Machining Calculator Software (FREE)
Page 1 of 2 12
Results 1 to 20 of 32
    Aug 2005
    90
    I have gained a great deal from the “ZONE” over the past 1½ yrs and would like give back a little to the members. I’m currently writing a small program that calculates various values that seem to be used while machining. Not knowing actually any of the formulas I began searching, and it appears that speed and feed are the most requested. Below is a list of what it can do so far along with the formulas that I used. If any of the formulas are incorrect please let me know so they can be corrected and any other function (along with formulas) that would be useful in the “hobby shop”. Keep in mind that I am self taught in VB and that my skills are limited.
    Current Functions:
    *Spindle Speed: speed = (cs)*3.82 / d
    CS = the sfpm of the material
    D = diameter of the cutting tool
    There is also a chart that can be edited for the different material CS values.
    *Feed Rate: feed = (chip load) * (# of flutes) * (spindle RPM)
    *Fractional to Decimal converter: (for those of us that need it)
    There is a database associated with the program so adding things as far as like drill sizes,Tap drills etc wouldn’t be hard to incorporate into the program. As I stated, I’m open to suggestions as far as what else would be nice to have, but I might not be able to accomplish all that is requested.
    Robert
    Oct 2006
    586
    are you wrighting this as a program you cam down load
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Oct 2006
    586
    my communications software has a pretty good calculator i use multi DNC v 7.0 build 28
    Aug 2005
    90
    yes, this will be a free downloadable program.
    Robert
    Oct 2006
    586
    thats good you can never have to many calculators
    Jun 2006
    47
    COOL!
    And... maybe add some formula's to calculate the machine itself?
    thumbs up!
    Attached Files Attached Files
    Aug 2005
    90
    Brunow,
    Looking at the attachment it would be fairly easy to do...just need to get one part of program up and de-bugged before adding any additional features
    thanks for the file
    Robert
    Jun 2006
    47
    now that's some good news to start the day with!
    Aug 2005
    90
    I have added a converter to go from decimal to fraction (in 64th). I was searching last night for some reference material for the suggested sfpm of various metals, didn’t find exactly what I was looking for, does anyone know of a web site that offers a chart or should I just get the latest “machinist handbook”? I would like to populate the database with some of the more common metals, aluminum, mild steel, tool steel, brass, stainless etc. for both “HSS” and “Carbide” tooling. While testing the application I did notice that placing a high “sfpm” say 400 and using a .250 tool resulted in a suggested RPM of 6112. Most mills “Hobby Class” don’t turn this fast, so is how is this overcome in the shop? Crank the RPM as high as you can and let’r rip?
    Thanks in advance
    Robert
    Aug 2005
    90
    Here is a screen shot of what it looks like so far, let me know what you think
    Robert
    Jun 2006
    47
    No idea how you do it. But it looks kinda cool!
    Nice idea adding some value converter to it. decimal - fraction. Maybe add inch - mm allso? :banana: (http://www.digitaldutch.com/unitconverter/index.htm)
    Aug 2005
    90
    Brunow,
    I will be adding a “metric” option to the program once I get the “inch system” going or I might just re-write (copy and paste…lol) a whole new program. Seeing how you are in Belgium, when it comes to machining formulas do you use the “inch” or “metric” system and do you have any links to the metric formulas?
    Robert
    Aug 2005
    90
    I have been work on a couple of issues the software has (1) rounding on the "decimal to fraction" (2) storing the data for recommended speeds. I currently have the decimal to fraction set to calc. 64th but there is a problem
    if you enter and decimal between .008 and .023 it will show 1/64" working on that, the other problem is I would like this to be a small application, currently the data for material speeds is store in a database (which you can edit) the only thing is it makes for a large program and supports files that need to be loaded on the host computer..I will post an .exe as soon as I get these ironed out.
    Robert
    Jul 2003
    1220
    I'm not sure a user would require a converter from decimal to fraction.
    I imagine it is quite hard to write code to make a fullproof converter for all decimals.
    Perhaps a dropdown window of the more common ones is all that is required.
    Nov 2004
    56
    I would like to start by saying "thank you for contributing". I can always use a calculator (be nice if one had everything you needed). A converter for fractions would be nice for those brain fart days. Can never have to many functions. Again thanks.
    Mar 2007
    This is quite cool, and I've been working on a 'shop calculator' of sorts as well. We've got different interests though, it seems. I'm starting off with a right angle calculator and adding similar features like sine bar buildups and also speeds and feeds. If you're looking for things to add, a right angle triangle calc would be an excellent addition. I know I'm not alone in that I'd prefer to use a program over trigonometry.
    As it is now, it looks really nice, I especially like the table of suggested speeds. Keep up the good work!
    Nov 2006
    154
    Why not simply look in the Machinists Handbook? From what I see, these are only guess's. This program does not take into account the type of coating on the tools, TIcn, Tinal, etc. A true machinist does not need a "program" to find out all this information. Example... carbide at 300 SFPM in low carbon steel? See what you get at 700 SFPM at .090 DOC
    Steve
    Nov 2004
    56
    Question
    Hope you have not given up on this. Please post status of your project.
    Thanks a million.
    May 2007
    125
    Quote Originally Posted by RLC View Post
    Where`s the down load?
    Jan 2006
    153
    Steve
    This place is full of non machinists that don't own the handbook. They do spend money on parts and pieces to build machines and some buy machines.
    Just because this is a machinist forum doesn't mean you have to be a machinist to get something out of it. I think his program is a great tool for the rest of us non machinist dummies that don't own a handbook or have years of school and experience machining stuff. I think we probably fall in the hobby group...
Page 1 of 2 12
