586,838 active members*
2,600 visitors online*
Page 1 of 2 12
Results 1 to 20 of 28
    Aug 2015
    28
    4'x4' CNC plasma DIY project
    Hi everyone, i'm new in this world of CNC machines. I'm starting a new project that includes make a CNC plasma table, in this case I select a 4'x4' machine and I already have a few parts that enlist below:
    RM1605 1385 mm end machined ballscrews
    RM1605 single nut
    FF12/FK12 sets
    SBR20 1400 mm linear rail
    SBR20UU block bearing
    Nema 23 stepper motor
    162 mm linear shaft
    Steppet motor driver micro controller
    50W power supply
    CNC stepper couplers
    16 mm SCUU linear ball bearings
    I hope you can help me because I have a few questions about limitswitch, how use the software, how install the THC or what plasma cutter use, however, I will be updating the progress.
    Thanks for watching.
    Aug 2015
    28
    Re: 4'x4' CNC plasma DIY project
    For now, I receive the 36V DC 9.7A 350W Regulated Switching Power Supply
    Attachment 311386
    4x ball nut housings
    Attachment 311388
    1x 16 mm ballscrew 1605 and nut and lenght 135 mm
    Attachment 311390
    Also, a few aluminium and steel plates are in process to build it, I'm waiting for other pieces in a couple of days.
    Aug 2015
    28
    Today I picked up some pieces:
    Ballscrew 1385 mm with single nut
    Attachment 311720
    FF12/FK12 set
    Attachment 311722
    SBR20 1400 mm
    Attachment 311724
    Attachment 311726
    Flexible shaft coupling CNC stepper motor coupler
    Aug 2015
    28
    Thanks Assink, I'll see what I can find
    For now, I'm working on the electronics, the mounting board
    Attachment 316548
    Aug 2015
    28
    Today I receive the set of limitswitch
    Attachment 312042
    the 6 mm linear shaft for Z axis
    Attachment 312044
    50W 12V Switching power supply AC to DC
    Attachment 312046
    6000Z Metal Roller-Skating Deep Groove Ball Bearing 26mm x 10mm x 8mm
    Attachment 312048
    and I'm wating for the aluminium plates, this will take a week
Name:	Aluminium plates.JPG
    Aug 2015
    28
    For now i'm modeling the plasma table looking for any issues and find some distances wrong, nothing serious.
    Attachment 312462Attachment 312462
    Aug 2015
    28
    I'm working on the electronics and I'm waiting for the nemma stepper mounts for install it, Also I need to cut the grid slats but I have not found someone to make them on a CNC table
    Electronics mounting board
    Grid slats
    Aug 2015
    28
    Some progress
    Attachment 312506
    Sep 2011
    13
    I'm no expert but it looks good so far,
    You should consider what type of smoke and dust control system you are going with and integrate it in the early design stages. A water tray is cheaper but you might be looking at about 500lbs of weight added to your table, something to consider when sizing your members.
    Also, you can use 3:1 or 5:1 gearboxes with your step motors, looks like you show this in your model, you can find these used on ebay. Direct drive may or may not work best i guess it depend on your application.
    Neuron THC looks very good, I plan on getting one for my table when its up and running. Neuron CNC
    Hypertherm plasma cutter all the way! PM45 is CNC ready too
    Aug 2015
    28
    Finally an update, for now, I'm testing the CNC plasma table without the plasma cutter connected, I need to install the torch holder and grid slats to cut some pieces. Also I'm learning how to make better Gcodes in Inkscape. I think that the CNC is slow but it's better than nothing.
    If someone has any recommendation to test it or improve it is welcome.
    https://youtu.be/Z-31ttdOuQ0
    May 2016
    3
    Quote Originally Posted by hector-xj View Post
    Hector,
    I agree that it looks a little slow. While it would probably work, I'd expect rounded corners (from the heat) and probably an additional amount of doss in the cut. Depending on the thickness of your material anyway.
    One question. Only because it wouldn't cost too much more, had you though of using gears to add drive speed (at a loss of torque)? There would be additional math involved, but once it was all sorted out, I think you would have more versatility due to the increased speed.
    For my first project, I cheated. I purchased a R7 (Router) kit. I'll learn on this and hope to (in the future) use this to build my plasma table.
    Corey
    Aug 2015
    28
    Quote Originally Posted by coreyperez View Post
    Hector,
    Corey
    This is my very first CNC, I installed the system with screws because it was my first option, I had never seen a machine in person, only in videos. The X axis has two stepper motors connected in parallel and I think that is the reason why I can't increase the speed on Mach3 (up to 40 in/min doesn't work, only X axis), may be if I install another stepper driver, one per motor in X axis, it can be faster.
    In the future may be build another with gears, however, for now I will use it just like that to recover some money (4 months of been working on it)
    Hector
    Aug 2015
    28
    I'll put on the water tray later, firs I want to learn to use. To install the gearboxes I need to know how the stepper motor works and then put it on or not, this is my first plasma table so I have no experience
    Aug 2015
    28
    Yesterday I receive On/Off switches
    Attachment 313138
    5 Axis CNC Breakout Board For Stepper Driver Controller
    Attachment 313140
    Stepper motor driver CNC controller
    Attachment 313142
    Linear Ball Bearing Slider CNC Bushing
    Attachment 313144
    Also, the aluminium plates are almost finished
    Attachment 313148
    Attachment 313150
    Attachment 313152
    https://youtu.be/nphZm4JQBV8
    Aug 2015
    28
    I just installed the floating head and the THC3T-02 torch height control and everything works great and finally this is my very first piece made in my CNC plasma table built by me, I need some advices to make the cutting line thinner but for now it's fine to me
    For now, I need some practice to learn Gcodes and others things.
    Attachment 334708
    Aug 2015
    28
    Finally I got some stuff and I'm waiting for steel plates for the next week
    Screws
    Mounting board for the electronics
    Torch plates
    More torch plates
    Cable drag chain, controls, relay and electric fan
    Top guard
    Bench
    Attached Thumbnails Attached Thumbnails 12986557_10204332088460846_398377415_o.jpg
    Aug 2015
    28
    First armed piece
    Attachment 315864
    Aug 2015
    28
    Hi everyone, I hope that someone can help me, I found this plasma cutter, Thermal Dynamics Cutmaster 52, and want to know if can be connected easily with the system of the cnc plasma table, any recommendation?
    Attachment 315948
    Aug 2015
    28
    Hi everyone, I need some help.
    Recently I bought a plasma cutter and I need to know how to connect an Miller 625 Spectrum to the CNC plasma table system, is there someone who knows how it works?
    This is the Miller 625 Spectrum
    Attachment 316370
    Jan 2010
    17
    try plasmaspider.com that forum has a lot more knowledge on CNC plasma cutters
Page 1 of 2 12
  1. DIY ShopBot CNC Plasma Project
    By DJDLabs in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 12-22-2016, 04:12 PM
  2. Possible New Project- CNC Plasma CUtter
    By Type75 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 08-21-2014, 04:10 PM
  3. New 4x4+ plasma table project
    By drboostv6 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-28-2012, 01:04 AM
  4. Plasma 4x4 project
    By Jdmproject in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-11-2011, 02:50 AM
  5. 4 x 4 Plasma table project
    By jermu in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-02-2010, 08:28 AM
