Ho hum..........
It's always a pain to admit failure :tired: but it's the only way.
(For new readers, I'm afraid you'll have to refer back to earlier posts of mine for the relevance of this piece of kit to the current thread.)
The particle separator works in principle, but I can see that I could spend the next 12 months getting it right.
As the attached photos may show, the 6ft long beast did give some separation into sizes from 600 microns down to 100 microns, as measured, but there was so much overlap in the size scattering that no useful data might be inferred from what I could see.
It would need a much slower feed mechanism to avoid particles interfering with each other as they fell through the air stream. Also a much better collection method to keep them apart when they reached the base.
Whether it's turbulence in the air stream that's causing it I'm not sure, but I was surprised at the amount of sideways drift from the central input line.
It might also be due to the irregular shape of the sand particles, or just the fact that it is Saturday.
Too many imponderables to make it worth pursuing, I think.
I shall resort to finding a collection of screen materials 3mm to 200 microns, and assume anything that gets through that is part of the 150 -200 micron range. Then make up de Larrard's recipe with known finer particles, zeeospheres etc.
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
