I created a linear bearing out of EG and a new formula for Low Friction paste.
After a ton of research, I decided to buy some different powdered metals and lubricants: Aluminum, Copper, Brass, Bronze, PTFE (Teflon), Graphite, Molybdenum Disulphide.
The EG formula for the housing is the 1/6 each (PPV) of #6 Alox, #4 Quartz, #2 Quartz, #2/0 Quartz, Z800, Cabosil M-5 which is a slight modification of the current formula in that I swapped the Z200 for Cabosil Fume Silica.
The EG/LF compound is (PBW):
5 - Epoxy (Resin and Hardener)
1 - Molybdenum Disulphide powder (Dow Corning Z Moly-Powder)
1 - Graphite
1 - Aluminum
1 - 3M G-200 Zeeosphere's
0.5 - Copper
0.3 - Cabosil M-5
0.2 - PTFE - BYK Ceraflour 980
This makes a very pourable mix that de-airs quickly.
This bearing is based on a set that I had: Thomson TWN-10-OPN 5/8 shafting.
I do not have pictures of the mold and molding operation… they were lost… grrr grumble grumble... wife... grumble.
It was a wood mold OAK/MDF that was sprayed (2 coats) with PVA and allowed to dry. Taking it apart was easy on the MDF but the Oak pieces were a little too attached which required a more destructive level of force to remove. However, the PVA did do its job with about 90% of the surfaces separating cleanly. PVA on MDF (sealed with shellac) was 100% perfect.
Next time I do this I will make one bearing that’s 2 feet long and use aluminum sheet to separate the segments and UHMW for the body.
The shaft is very stiff in the block right now, I'm going to let it finish curing another 24 hours before I try to lub it up and lap it if need be.
Here’s the pictures:
