Creep of epoxy seems to be a concern at high temperatures such as soldering circuit boards or wave soldering.I cannot find any information on creep at room temperatures.Probably not the same as creep,here is a copy...
"Abstract
Adhesive bonding of aircraft primary structures has been in use for over 50 years and is still in use on current aircraft projects as a direct alternative to riveting. Bonding of stringers to skins for both fuselage and wing construction and of metallic honeycomb to skins for elevators, ailerons, tabs and spoilers are the main uses for adhesives. Details of the historical use of adhesive bonding on commercial aircraft and how the adhesive materials developed are given. "
Epoxy bonded aluinium aircraft parts go through extremes of temperature and forces every day.Conclutions:
Should I be afraid to fly?
Should I be afraid to build an E/G machine?
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
