586,655 active members*
2,503 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy-Granite machine bases (was Polymer concrete frame?)
Page 24 of 253 1422232425263474124
Results 461 to 480 of 5053
  1. #461
    Jul 2006
    1256
    Jsage we are not really having a dry humor contest.Strange,weird,humorous ideas lead to good solutions.It gets people thinking,new ideas evolve.It seems to promote members posting what they may think is crazy ideas but the proof is in the puddin,we have 426 good informative posts.As far as I am concerned the dry humor posts have helped to discouver new ideas.I hope any dry humorous posts have a buried serious note.
    Thanks for all the good posts.
    Larry
  2. #462
    Sep 2006
    157
    LOL,
    Cheers Larry, and all. I'm going back to my own mission for now.
    mike
    and the sage is short for sagebrush. Not like I usually have something sage to say ; )
  3. #463
    May 2003
    792
    Quote Originally Posted by lgalla View Post
    This is longer than waiting for 8' thk's to appear on E-bay...
    You're after them as well? I have a feeling it'll be a long wait..
  4. #464
    Jul 2006
    1256
    Walter actually ther has been long rails on E-bay.To-day SR15's 101" long went for $600 a pair.A guy had 10 sets HSR45's with 36 ft of rail and 4 blocks.Some went for $200.He would not ship to Canada so I lost out there.I will PM you if anything good comes up.
    Larry
    PS It is probably better to just buy HIWINS in the size you need.
  5. #465
    May 2003
    792
    Good info. Thank you.
  6. #466
    Dec 2006
    325
    The downside is if you want to vacuum clamp through a MDF spoil board 4'X8' the vacuum pump must be 15hp or confined to purpose confined hold down areas,resulting in slower production rates.
    How do you intend to secure the spoil board?
    If i understand correctly you need 15hp to suck through the MDF?
    What if you make grooves that would be in line with the vacuum holes,
    would you need less hp then?
    If your concerned with having to allways use vacuum on 100% of the surface, there could be ways of making simple manifolds and using ball valves to concentrate vacuum where it's needed, and maybe not use so much HP?
    best regards
    Bruno
  7. #467
    May 2005
    674
    You can secure the spoilboard to the table with the vacuum grid. The vacuum grid can be molded into the E/G table itself. That would save a heap of money over machining a solid aluminum 4x8 plate. Aluminum and E/G theoretically have the same density, and theoretically have a 15 times price difference ($5.00/pound for aluminum here in Northern CA, 30 cents for E/G).
    Also, when using a spoilboard, perfect flatness of the E/G table is unnecessary. The self leveling nature of the epoxy should give sufficient flatness.
  8. #468
    Dec 2005
    1408
    Testing, testing
    Has the cnczone server gone "clunky" ????
    Martin
  9. #469
    Jun 2005
    1436
    Yes, for the last twenty minutes, on and off !
    John
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
  10. #470
    Dec 2005
    1408
    The density of polystyrene and strength is of little use in E/G,urethane is the way to go.
    Larry
    Dear all,
    I think there has been some trouble with the server. Hence previous test transmission.
    Anyway, could we return to Bruno's ripping idea of casting-in rigid foam panels briefly, before the whole caravan moves on yet further?
    I totally agree that expanded polystyrene has little strength, but extruded polystyrene (eg some grades of Dow's Styrofoam) can have compressive strengths in excess of 70 psi. However Styrofoam has a coefficient of linear thermal expansion that is eight time greater than granite, and this might cause problems.
    I had to insulate a high temperature in-line air heater battery a while ago, and was worried about the insulation melting (or worse). The stuff we used is called FOAMGLAS It is glass that is "blown" into a foam using an inert gas.
    There are various different grades available but one of the strongest is HLB 1600 which has a density of 10 lb per cubic foot and a compressive strength of a whopping 232 psi. It gets better....the coefficient of linear thermal expansion is absolutely identical to that of granite.
    OK, compressive strength is only part of the picture, but to put it into perspective, you could build a solid brick wall 300 feet tall with the bottom course of bricks replaced by this foam.
    Here is a link to Foamglas (structural properties are on page 16)..
    http://www.foamglasinsulation.com/literature/FI201.pdf
    It might be worth looking into.
    Best wishes
    Martin
  11. #471
    Dec 2005
    1408
    Quote Originally Posted by greybeard View Post
    John
    Dear John,
    Twenty minutes! You were lucky!
    More like three hours from my neck of the woods.
    Best Wishes
    Martin
  12. #472
    Sep 2006
    157
    martinw,
    Will definitely give it a read. Checked the first couple of pages and was intrigued. Gotta run.
    One semi aside. If the overall engineering is good, then perfection of the epoxy granite fabrication becomes less critical.
  13. #473
    Jun 2005
    1436
    Martin - your mention of foamglas put me in mind of a product that is/was used as a polyester filler, hollow glass spheres. Can't drag the memory back, but it might have been called something like "microspheres"? Poured like dry sand, and got everywhere when I tried it about 30 years ago !
    Obviously a possible low density substitute for the sand rather than for macro inserts like your foam blocks.
    John
  14. #474
    Jul 2005
    12177
    John
    Maybe a low density substitute but not a low cost substitute.
    http://www.fibreglast.com/showproduc...llers-111.html
    $66 for 3 lbs, about one cubic foot.
  15. #475
    Jul 2006
    1256
    Hi Martin I was out 4or5hours.I was worried my bad puns got me kicked off the Zone.
    Larry
  16. #476
    Dec 2005
    1408
    Larry
    Larry,
    You cannot escape your challenge to me of a duel over bad puns so easily, and by blaming the CNCZone server. It is a matter of honour, probably conducted in mist-shrouded woods, at dawn, with PCs at 5000 miles apart.
    Best wishes
    Martin
  17. #477
    Jul 2006
    1256
    Hey Bruno& Zumba back to the vacuum table.
    If you are high production,you do need 15to20hp vacuum like the big boys sucking through MDF or LDF.They gurantee holding one sqft with the rest of the table open.Naturally Zoneing reduces the requirements.As I have a small 15cfm pump I will experiment with it.Perhaps a vacuum storage tank would help.An aircompressor tank is not suitable as it will collapse under vacuum.Really!
    Zumba I have not studied the grid table so am dumb on the subject.As a first project for your router could you attatch a solid plastic sheet to the top and rout the slots???Rather than trying to cast the grid.
    Larry
  18. #478
    Not necessarily. If you are running lots of the same parts, a dedicated fixture will let you get away with very little CFM, provided you get a good seal. But if you want to cut out sheet after sheet of varying nested parts, than yes, you will need to be sucking through a spoilnard with a high CFM pump. Be prepared for a LOT of noise from that pump, too.
  19. #479
    Jul 2006
    1256
    Right on Gerry,could naw said it better myself.Great spelink Eh!!
    If you plan a router for high production you have to be prepared to possibly spend 8 grand on a pump.
    Gerry a sales guy once told me besides the noise."If you have a 3000sqft shop and a 15 to 20hp vacuum,you will need air conditioning in the summer and no heating bills in the winter"I guess they produce lots of heat???
    Larry
  20. #480
    Not as much as our 50HP compressor. runs at about 190°
  1. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  2. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  3. Replies: 9
    Last Post: 01-15-2014, 11:39 AM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. Epoxy-Rice Machine Bases (was Polymer rice frame?)
    By mdierolf in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2008, 04:16 AM
