586,647 active members*
1,977 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy-Granite machine bases (was Polymer concrete frame?)
Page 89 of 253 3979878889909199139189
Results 1,761 to 1,780 of 5053
  1. #1761
    Apr 2007
    777
    Walter,
    It's probably obvious but don't forget to thoroughly degrease the aluminum parts (perhaps with acetone) and perhaps also roughen the surface a bit with coarse sandpaper for maximum adhesion. I'd personally try to avoid even fingerprints on the aluminum but that may be overkill.
    You're looking real good on this. I can't wait to see your results!
    --Cameron
  2. #1762
    Jul 2005
    12177
    I don't know if it would be feasible for any aluminum parts you will be embedding but I have found anodizing improves adhesion of epoxies to aluminum. And if the pre-anodizing alkali etch is a bit prolonged to give a dull finish it is better.
    And it is important to keep your fingers off the anodized surfaces; you want them going into the epoxy as pristine as they came out of the sealing tank.
  3. #1763
    May 2003
    792
    Those are very good advices, thank you!
    I'm still 2 or 3 weeks away but pushing hard.. Ordering vibrating motors, wax. And you know what? I'm going to use one of those cool KitchenAid mixers! You know the funky color ones.. I found a used one on Ebay. Mixing epoxy with aggregate was the only awful part and now I'm going to actually enjoy it.
    I forgot to ask about tool cleaning. This job will take many hours- how do I keep the mixing fork clean? Do I have to clean it between batches? I may not have the time. And I don't want to use lacquer thinner. Any ideas?
    _
  4. #1764
    Jun 2005
    1436
    I'd suggest you wax the joints of the mold before you assemble it. If you get a small leak down into the joint, especially where the screws go through, just imagine the problem of taking it apart.
    Better grease the screws too.
    Methanol for the cheapest cleaning up of tools ?
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
  5. #1765
    Jul 2006
    1256
    Methyl hydrate is a good cleaner,cheap and you can get it at Home Depot.
    You must clean between batches as any leftover epoxy will accelerate the next batch.Scraping the sides of the container and wiping the mix blade is probably enough depending on how fast you get to the next batch ,or use a fresh cheap plastic bucket every mix.The bucket is probably cheaper than the solvent to clean it.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
  6. #1766
    Apr 2007
    777
    The many names of Methyl Hydrate
    Methyl Hydrate=Methyl Alcohol=Methanol=Lacquer Thinner=Fondue Fuel=Wood Alcohol
    These are all the same thing for any out there who are confused. I think those on the other side of the pond also use name Methylated Spirits.
    --Cameron
  7. #1767
    Jul 2005
    12177
    Quote Originally Posted by ckelloug View Post
    --Cameron
    Lacquer Thinner also contains other solvents such as Toluene or Methylene Chloride. It is a more powerful solvent than straight Methanol.
  8. #1768
    May 2003
    792
    I've used lacquer thinner in the past- I'm just afraid it may affect the composite.
    But I do like it's simplicity..
  9. #1769
    Apr 2007
    777
    Walter,
    Lacquer Thinner with the added components Geof Mentioned in some varieties or plain methanol are both very volatile. If you leave the cleaned utensils out in the sun for a few minutes when it's hot out, I'd figure you had a pretty darn good chance of 100% of them evaporating. Actually, leaving them on a bench in a cool room is likely to have them evaporate too. Methanol fumes and especially the extra "god knows what" in lacquer thinner are not healthy.
    --Cameron
  10. #1770
    May 2003
    792
    BYK C8000 Coupling Agent
    This one is so hot the vapor hasn't condensed yet. It's still vaporware in terms of buying it but since nobody will sell us anything, the fact that samples are available bodes well for this crowd.
    Here's the datasheet. The datasheet is not as complete as the blurb you posted. http://www.byk.com/output/download/E500_USA.pdf
    Because they cite results of an amine titration in the datasheet, it will increase the required hardener in our epoxy.
    I missed that part.
    How much more hardener? The total amount of C8000? I'm using about 2g per 600g sample.
  11. #1771
    Apr 2007
    777
    Walter,
    Let me look into this. I expect that the answer is miniscule but I never did go through the chemistry to find out. I'll try bugging a BYK apps engineer this afternoon about the A 8000.
    --Cameron
  12. #1772
    Apr 2007
    777
    Walter,
    From what I've been able to find on the web, mix ratios that are within 5% of the specified ratio are going to work fine. Since the 2g of BYK C8000 are apt to be a drop in the bucket compared to 600 g of epoxy, my best theory says that in a batch of this size, don't worry about the BYK C8000. I still don't have a 100% understanding of the chemistry here, but I think you're all right in terms of just ignoring the effect.
    --Cameron
  13. #1773
    Oct 2005
    Filling a milling machine column with concrete
    I have done that on a small Bridgeport type milling machine with high strenght 240 Kg/cm2 concrete with 3/4" agregate and it simply turned the machine incredibly solid and its vibrations in discontinue milling were reduced to almost negligible.
    SACEM
  14. #1774
    Quote Originally Posted by Geof View Post
    I looked at the msds for the Home Depot laquer thinner I have, and it's only 20% methanol. Mostly Hexane (Naptha) with the other stuff that was mentioned.
    Walter, West System sells an aluminum etching solution for bonding with epoxy. They also recommend "wet sanding" with epoxy and 80 grit paper.
  15. #1775
    Jul 2006
    1256
    Straight Methyl hydrate works very well for cleaning epoxy from tools.Stay away from lacquer thinner it is more volatile .The methylene chloride component is highly toxic and used in paint strippers.Residue may hurt your epoxy mix.
    Methyl hydrate will evaporate very fast and will not contaminate the mix.Being a alcohol,It is actually can act as a catalyst with epoxy.This stuff evaporates so rapidly any residue from cleaning will not be there in a few minutes.Also methyl hydrate is half the cost of lacquer thinner.In a pinch,if you have no methyl hydrate,here in Canada we have an alcohol called Crown Royal.I hear it will work but have not tried it myself.It is 4 times the cost of lacquer thinner.MSDS flammable liquid.If ingested ,it is better "ON THE ROCKS"????Must mean on the granite rocks.High toxicology!!!May cause intoxification,bableing and affect posts.Use in low %ages.
    BYK-C8000?Missed the posts on this.It is not available until August.If using this or other chemicals check the MSDS please.
    Walter I may be behind in reading posts.Recent posts suggest you are embedding aluminium.Is this so.
    Larry
  16. #1776
    May 2003
    792
    Great stuff, thank you all!
    Another awesome post from Larry.. And yes, I am embedding aluminum. I have this Single Plane idea and no place to use it so I'm just going to put it in here.
    It takes care of rail mounting so I can worry about other stuff. Like sportiness.
    Speaking of which.. Check out the detail on this E/G leftover! It was dumped into the plastic box, placed on a shaker and pressed. These letters are 1/8" tall. I think it's the G800 Zeeospheres.. There's a huge difference between G850 and G800- one is 12-200 micron and the other 2-200 micron but the grading is different. They're world apart. See picture #2.
    Thanks for all the great advice.
    _
    Attached Thumbnails Attached Thumbnails Fine detail with G800 Zeeospheres.jpg   Zeeospheres G800 vs G850.jpg
  17. #1777
    May 2005
    89
    I think you should use steel instead of aluminium because of vibrations. Just a thought.
  18. #1778
    May 2003
    792
    Thanks Eson.
    Steel would have been a better choice - cast aluminum sustains like a $3k Gibson Les Paul (For the uninitiated- it's 14 seconds ).
    The other side of the argument is that it's pre-ground and easy to maneuver- I don't really have any metal working tools. I'm building my router with 2 screwdrivers, one power cord and $38 Harbor Freight benchtop mini drill.
    It's also a woodcarving machine- already too rigid and powerful for my needs. Joe's CNC model 2006 would be enough.. I'm into 3d carvings:
    _
  19. #1779
    Apr 2007
    777
    No Go on BYK C-8000
    Walter et. al.,
    I just received the following from BYK technical support indicating that C8000 is not effective in epoxy.
    <Blockquote>
    Hi Cameron,
    I am sorry, but I have to let you know, that the product C8000 is not effective in epoxy systems.
    For epoxy we have only products to reduce the viscosity and get a better wetting of the fillers. For example BYK-W 985 or BYK-W 995. The amount would be 1% based on filler.
    The other possibility to may improve the mechanical properties would be to use an air release additive like BYK-A 530, because the air bubbles are small defects.
    Kind regards
    Elke Tendick
    Technical Service Ambient Curing Resins
    Plastics Additives
    BYK-Chemie GmbH
    Abelstrasse 45
    46483 Wesel
    Germany
    </Blockquote>
  20. #1780
    Mar 2004
    1661
    I was searching the Internet after something else, when I found this site.
    It's not any new information, but it seems to prove some of the ideas in this thread.
    http://www.pillevaran.com/Pages/PRO07-eng.html
    Regards,
    Sven
  1. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  2. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  3. Replies: 9
    Last Post: 01-15-2014, 11:39 AM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. Epoxy-Rice Machine Bases (was Polymer rice frame?)
    By mdierolf in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2008, 04:16 AM
