Hi all. I have an ACCU Mill with ball screws and a Centroid controller. This is a CNC retrofit. I have a problem with the X axis screw. There is lateral movement of the lead screw before the table moves. This is NOT backlash and the ball screw is not damaged. You can physically see the shaft move "in and out". This has caused roughly a .020 slop in the table movement. I suspect something is missing from one end of the shaft or the other. the drive motor is on the operators right. If you tighten the indicator dial (on the operators left) it removes the excess play. I have no diagram for this particular mill or for the retrofit. Even the company that does the retrofits on these machines seems to be of no help. Any help is greatly appreciated.
DD
